I NEED TO VENT!, (my crankcase) |
airsix |
Feb 3 2005, 01:52 AM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
I've been procrastinating away the winter, but it's time to address a few items before spring.
Oil leaks - Ok, this is my biggest problem and is the reason for this post. I'm getting a lot of crankcase pressure since I added the turbo. Off boost I've got no oil leaks. On-boost I've got leaks from the valve covers and pushrod tubes (both new and in good condition). I've got the rocker-box vents plumbed up to the spark-arestor where they are joined by the oil-filler vent hose and this three-into-one arangement then goes via single 5/8" hose to a home-made catch can. Do you think running these as three individual lines (rather than plumbing them down to a single 5/8" hose) would cure the problem, or do I need something more agressive in the way of venting/scavenging? -Ben M. |
SirAndy |
Feb 3 2005, 11:20 AM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
there is your problem! while the oil-filler neck always has positive pressure, the head-vents will have positive pressure at and above idle but will turn to *negative* pressure (sucky sucky) on higer rpms. for the catch can to be most effective, you'll need to route each to the can individually. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Lo-Fi Version | Time is now: 8th June 2024 - 11:19 PM |
