L-Jet914 |
Member ![]() ![]() Group: Members Posts: 357 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California ![]() |
Hello everyone. I recently purchased a used OEM intermittent wiper relay harness and it was supplied with a VW relay PN: 111 955 531. I followed the instructions on Jeff Bowlsby's website that was a copy of Sir Andy's post regarding the relay. My 914 is a 74. All wiring has been verified for their correct locations. Now here is the issue I am having. When I went to test the wiper system after installing the harness, I put the wiper stalk to the position below position 0 which is supposed to be for the intermittent function. When put into the position below position 0 the wipers run on low speed all the time. Now is the a relay issue not being the correct part number as OEM? According to the owner's manual it should operate once every 10 seconds if I remember reading it correctly.
L-Jet914 |
Thank you everyone so far for your input. My 74 1.8 is a 4/74 production and the owners manual stated if equipped with the intermittent wipers the position was below position 0. I did not know that even being pre-wired for the relay that there was a different wiper stalk.
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,229 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Thank you everyone so far for your input. My 74 1.8 is a 4/74 production and the owners manual stated if equipped with the intermittent wipers the position was below position 0. I did not know that even being pre-wired for the relay that there was a different wiper stalk. @L-Jet914 Stupid question, did you break off the tab on the stalk to allow the arm to go down to the intermittent position? (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 16th June 2025 - 12:31 AM |
