| Mr Beckstar |
Jan 25 2025, 05:37 PM
Newbie ![]() Group: Members Posts: 44 Joined: 28-April 18 From: Australia Member No.: 22,082 Region Association: Australia and New Zealand |
Hi all.
I have a 4 cylinder 2 litre and am adding a remote oil filter and oil cooler circuit via a spin on adaptor attached to the stock oil filter console mount. But I noticed the oil filter bypass valve in the stock oil filter mount (circled in photo below) and now I’m concerned that, at high rpm, I’ll be bypassing the remote cooler/filter circuit. Does anyone know the bypass valve relief pressure setting? Knowing that would at least allow me to judge whether it’s an issue. |
| Superhawk996 |
Jan 28 2025, 10:15 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,040 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I don’t want to answer for OP but my understanding is he is worried about bypassing his external oil cooler and overheating. Operating oil pressure hasn’t been part of this conversation.
I view this discussion as largely theoretical. Unless the external oil cooler and plumbing is stupid restrictive the bypass in the oil filter console is a non issue. On the other hand, if you do have a HIGHLY restrictive external cooler and hose assembly, the last thing in the world that you ought to be doing is plugging or increasing the relief pressure of the oil filter console bypass. That situation of high external oil cooler restriction, is basically the same limitation of oil flow as a plugged & restricted oil filter. This can cause bearing damage due to loss of pressure and flow at the bearings. Which of course, is why the automotive engineers that designed the system put the oil console relief valve in there in the first place (ie to ensure oil gets to the bearings). This is why I initially suggested that the oiling diagram be looked at closely. |
| GregAmy |
Jan 28 2025, 10:23 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,699 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
I don’t want to answer for OP but my understanding is he is worried about bypassing his external oil cooler and overheating. I suggest it's a non-issue. But if you're that worried about it then stop using those cheesy cheap-ass sandwich adapters and use one of Chris' good bespoke ones: https://tangerineracing.com/shop/ols/produc...-oil-cooler-kit |
| Mr Beckstar |
Jan 29 2025, 04:26 AM
I don’t want to answer for OP but my understanding is he is worried about bypassing his external oil cooler and overheating. I suggest it's a non-issue. But if you're that worried about it then stop using those cheesy cheap-ass sandwich adapters and use one of Chris' good bespoke ones: https://tangerineracing.com/shop/ols/produc...-oil-cooler-kit Because I’ve never seen this option! I’ll check it out. |
Mr Beckstar Bypass Valve on Stock Oil Filter Console Jan 25 2025, 05:37 PM
Montreal914 Good concern and already discussed here in the pas... Jan 25 2025, 06:09 PM
Mr Beckstar
Good concern and already discussed here in the pa... Jan 26 2025, 05:16 AM
Montreal914 Looks like it is a couple of psi.
Read @[url=htt... Jan 26 2025, 09:55 AM
Superhawk996 I hate chiming in on this because I don’t have a... Jan 26 2025, 12:38 PM
technicalninja :agree:
I believe every single ICE engine with b... Jan 26 2025, 01:00 PM
Mr Beckstar Thanks for the great responses everyone :D
If i... Jan 27 2025, 07:11 AM
Superhawk996 Where in the world did you come up with 3 psi?
I ... Jan 27 2025, 07:44 AM
Mr Beckstar
M... Jan 27 2025, 07:17 PM
Superhawk996
I’m also a mechanical engineer and done a fair... Jan 27 2025, 08:15 PM
Mr Beckstar
I’m also a mechanical engineer and done a fai... Jan 28 2025, 01:31 AM
Superhawk996
The spring will dictate the [force], the [area] i... Jan 28 2025, 07:54 AM
Mr Beckstar
The spring will dictate the [force], the [area] ... Jan 29 2025, 04:00 AM
emerygt350 And why on earth would you want to send cold oil t... Jan 27 2025, 06:22 PM
Mr Beckstar
And why on earth would you want to send cold oil ... Jan 27 2025, 07:22 PM
technicalninja
... Jan 27 2025, 08:19 PM
Mr Beckstar
Sadly, the old saying "if you want somethin... Jan 28 2025, 01:35 AM
technicalninja
I’m also a mechanical engineer and done a fai... Jan 27 2025, 08:25 PM
Mr Beckstar
[quote name='Superhawk996' post='3189070' date='J... Jan 28 2025, 01:38 AM
GregAmy Can I insert just a couple basic questions here?
... Jan 28 2025, 08:11 AM
Mr Beckstar
... Jan 29 2025, 04:16 AM
Superhawk996
I suggest it's a non-issue. But if you're... Jan 28 2025, 10:27 AM
Mr Beckstar
…I view this discussion as largely theoretica... Mar 11 2025, 04:17 AM
Mr Beckstar I looked at those two links and they’re not rele... Jan 29 2025, 04:24 AM
Mr Beckstar The oil filter bypass valve piqued my interest so ... Feb 21 2025, 03:31 AM
Mr Beckstar The above pressure readings were measured using th... Feb 21 2025, 04:10 AM
Superhawk996 Interesting data points.
Food for thought on the ... Feb 21 2025, 08:40 AM
Mr Beckstar Okay, I just used a brand new gauge with 0-15 PSI ... Mar 11 2025, 03:13 AM
Mr Beckstar Next step is to fit the two pressure tappings into... Mar 11 2025, 03:29 AM
Superhawk996 You’re in uncharted territory as far as I know. ... Mar 11 2025, 07:06 AM
Mr Beckstar
You’re in uncharted territory as far as I know.... Mar 12 2025, 02:29 AM
Superhawk996 Food for thought
If you look at histograms of av... Mar 12 2025, 07:55 AM
Mr Beckstar
Food for thought
If you look at histograms of a... Mar 13 2025, 01:49 AM
Superhawk996
At 68 MPH, the engine’s doing 4,200 rpm. Bei... Mar 13 2025, 06:46 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th September 2026 - 12:54 AM |
