L-Jet914 |
Member ![]() ![]() Group: Members Posts: 357 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California ![]() |
Hello everyone. I recently purchased a used OEM intermittent wiper relay harness and it was supplied with a VW relay PN: 111 955 531. I followed the instructions on Jeff Bowlsby's website that was a copy of Sir Andy's post regarding the relay. My 914 is a 74. All wiring has been verified for their correct locations. Now here is the issue I am having. When I went to test the wiper system after installing the harness, I put the wiper stalk to the position below position 0 which is supposed to be for the intermittent function. When put into the position below position 0 the wipers run on low speed all the time. Now is the a relay issue not being the correct part number as OEM? According to the owner's manual it should operate once every 10 seconds if I remember reading it correctly.
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,156 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Center right tab in picture
Attached image(s) ![]() |
friethmiller |
Senior Member ![]() ![]() ![]() Group: Members Posts: 917 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region ![]() ![]() |
Center right in picture @914Sixer - Thanks for the photo! But I'm going to need an arrow or a circle drawn on the image to understand where to look. (IMG:style_emoticons/default/wacko.gif) Is it that black tab sticking up on the right hand side? |
Lo-Fi Version | Time is now: 16th June 2025 - 12:58 AM |
