| busterphysic |
Dec 16 2024, 01:04 AM
Newbie ![]() Group: Members Posts: 38 Joined: 2-November 24 From: Santa Rosa, CA Member No.: 28,444 Region Association: Northern California |
Hello World!
I’m working to “Revive a Junk Title” on a 914 in California. The 914 was registered in California when it was in an accident and declared a total loss by insurance. I got the car with ABetter.bid from CoPart Auctions in Long Beach, CA. I completed the accident related repairs. Yay!!! Now, I’m focusing on reviving the salvage/junk title. I’d like to prioritize the work, so I can get a license plate and wheels on the road ASAP. Then continue with less critical repairs. The two steps ahead are passing a Vehicle Safety Systems Inspection (VSSI). Then the CHP Verification of Vehicle. I'll post about the CHP Verification later. So, I found the California VSSI manual here: https://www.bar.ca.gov/pdf/manuals/VSSI.pdf Running through the VSSI manual it appears more difficult than I expected. And I might need to repair a lot of incidentals. Rats! My neighbor Robert suggested I consult the forum before going overboard. My 914s concerns: VSSI 3.4.A Windshield Wipers A) “Every wiper activates and operates as designed by the manufacturer.” My wipers only run at a single, slow speed. Fast wipe is slow. Will I fail? VSSI 3.6 Seatbelt “If the vehicle is equipped with any seatbelt warning lights or seatbelt alarms, every seatbelt light or seatbelt alarm in the vehicle must be functioning as designed by the manufacturer.” My Seatbelt light and starter interlock don’t work. Do I need to fix the handbrake switch, seatbelt buckle switches, passenger seat cushion switch, seatbelt dash light, starter interlock, buzzer relay et cetera just to pass this VSSI???!!! My current seatbelts are “Worn”. They release and retract reluctantly, and the webbing was stretched in the crash. I purchased, but haven’t yet installed, Rennline seatbelts: https://www.rennline.com/rennline-retractab...lt-sku-sa-5053/ These seatbelts don’t have Safety switches in the buckles. Will these seatbelts pass? VSSI 4.2.C Tire Pressure C) “... inflation specification is normally recorded on label …” I have 195/55R15 85V Toyos instead of the 155 SR15 tires listed on the OEM label. Do I need to add a new label? Switch tires? VSSI 5.8.2 Parking Brake Light “The dashboard parking brake light turns on/off …” Seriously??? Rats! VSSI 7.2.B Bumpers “... verify vehicle has bumpers (as equipped by the manufacturer)…” Do I need to but the horns on the bumpers? VSSI 7.2.D Unibody “...Inspect for damage that could allow gasses or fumes into passenger compartment” I have some small tears under the center tunnel. Do I need to fix these now or later? Thanks All!!! And sorry for the length. Dave |
| busterphysic |
Feb 4 2025, 03:07 PM
Quick update.
Some more safety check items satisfied: I got the handbrake switch, buzzer relay reinstalled. This dash light now works. I reinstalled the oil pressure switch for its idiot dash light. Repaired the defroster lever box. Broken lead board. Bent/rusty cables. Replace bowden cables. Remove Fuel Tank. Rusty. Have a new tank. Only source gas line attached. Return fuel line unattached (Carbs). Attached B-Quiet pads to new tank. Should I seal the new fuel tank??? Remove fresh air box. 914rubber refresh kit. Add grille. Remove defroster diverters. Clean. Replace bowden cables. Remove wiper motor. High speed doesn't work. But motor is fine. Must be back at the steering column switch? 914rubber refresh. Replace angled grommets on brake lines under fuel tank. Driver's door latch's return spring broke. Replaced it. More to come ... -Dave |
busterphysic Reviving a Salvage/Junk Title in California Dec 16 2024, 01:04 AM
busterphysic Here is the VSSI manual. Dec 16 2024, 01:10 AM
930cabman :wttc:
an adventure for sure, DMV can be a chall... Dec 16 2024, 06:02 AM
JeffBowlsby What year 914? Dec 16 2024, 08:29 AM
busterphysic
What year 914?
Thanks Jeff,
LOVE your website.... Dec 16 2024, 11:18 AM
914_teener Ditto.... Dec 16 2024, 10:35 AM
JeffBowlsby Welcome to 914world Dave. :wttc:
My understand... Dec 16 2024, 12:08 PM
busterphysic Thanks Jeff.
The VSSI doesn't involve smog.... Dec 16 2024, 01:07 PM
busterphysic Hi All,
I see now that I need a CHP check not DMV.... Dec 16 2024, 01:43 PM
fiacra
Hi All,
I see now that I need a CHP check not DMV... Dec 16 2024, 02:08 PM
76-914
Hi All,
I see now that I need a CHP check not DMV... Dec 16 2024, 05:20 PM
tygaboy I'm Chris. We met a while back. Your neighbor ... Dec 16 2024, 05:38 PM
busterphysic Hi Chris,
Thanks for making contact. I had cold... Dec 16 2024, 08:41 PM
busterphysic Great info Fiacra!
Registration was paid Thur... Dec 16 2024, 08:33 PM
BuddyV Hey Dave! Robert here (your neighbor from 6 do... Dec 16 2024, 10:43 PM
Cairo94507 :wttc: With Robert and Chris in your neighborhood ... Dec 17 2024, 08:10 AM
busterphysic
:wttc: With Robert and Chris in your neighborhood... Dec 17 2024, 12:05 PM
DennisV
I’m working to “Revive a Junk Title” on a ... Dec 18 2024, 02:29 PM
busterphysic Thanks Bob!
I’m working to “Revive a J... Dec 18 2024, 07:29 PM
busterphysic I spent all day labeling gauge wires and burnishin... Dec 18 2024, 07:56 PM
DennisV
I spent all day labeling gauge wires and burnishi... Dec 21 2024, 07:49 AM
busterphysic Brother P-Touch labelmaker.
I spent all day lab... Jan 3 2025, 02:06 PM
busterphysic And only one casualty. Dec 18 2024, 07:57 PM
930cabman whoa, looks like alot of work Jan 3 2025, 02:46 PM
colingreene I know the previous owner well.
The car being tota... Jan 3 2025, 09:42 PM
busterphysic
The car being tot... Jan 7 2025, 01:05 PM
busterphysic Better labels.
Jan 7 2025, 09:52 PM
busterphysic Yay, I got the "Fasten Seatbelts" light ... Jan 8 2025, 10:01 PM
busterphysic
Yay, I got the "Fasten Seatbelts" light... Jan 8 2025, 10:02 PM
busterphysic
Yay, I got the "Fasten Seatbelts" light... Jan 8 2025, 10:04 PM
busterphysic
Yay, I got the "Fasten Seatbelts" light... Jan 8 2025, 10:05 PM
busterphysic Hi all.
Now I need to replace the HandBrake conta... Jan 8 2025, 10:08 PM
busterphysic Hi All!
Should I seal the new fuel tank I am... Feb 4 2025, 02:54 PM
fiacra
Hi All!
Should I seal the new fuel tank I a... Feb 4 2025, 03:17 PM
busterphysic
Hi All!
Should I seal the new fuel tank I ... Feb 4 2025, 03:40 PM
busterphysic I put 6 sq-ft of B-Quiet in the fuel compartment.
... Feb 11 2025, 05:46 PM
VaccaRabite Uh-oh.
You may regret the sound deadening in the f... Feb 11 2025, 05:59 PM
busterphysic
Uh-oh.
You may regret the sound deadening in the ... Feb 14 2025, 12:00 PM
914sgofast2 I did not have any big headaches when I removed an... Feb 12 2025, 09:23 PM
busterphysic
I did not have any big headaches when I removed a... Feb 14 2025, 12:05 PM
busterphysic
I am replacing the 3-hole air-box bowden-cable s... Feb 14 2025, 12:49 PM
busterphysic
I am replacing the 3-hole air-box bowden-cable ... Feb 14 2025, 02:08 PM
Justinp71 I had to do something similar for registering a ca... Feb 18 2025, 12:48 PM
busterphysic
I had to do something similar for registering a c... Feb 18 2025, 01:29 PM
busterphysic Closed up the driver's door today. It's b... Feb 19 2025, 07:00 PM
busterphysic
Installed new vapor barrier. Feb 19 2025, 07:03 PM
busterphysic
Upgraded to chrome window cranks and interior do... Feb 19 2025, 07:06 PM
busterphysic
Polished wheel caps. Feb 19 2025, 07:30 PM
rjames Call me crazy, but I really like the white Fuchs o... Feb 19 2025, 07:57 PM
busterphysic
Call me crazy, but I really like the white Fuchs ... Feb 19 2025, 09:03 PM
busterphysic
Hi all,
I'm shrinking tubing onto the free... Feb 21 2025, 12:19 PM
busterphysic RE: Reviving a Salvage/Junk Title in California Feb 21 2025, 02:05 PM
busterphysic RE: Reviving a Salvage/Junk Title in California Feb 21 2025, 02:29 PM
busterphysic Wipers in Friday.
New rubber bushings and isolator... Feb 24 2025, 10:27 AM
930cabman
Wipers in Friday.
New rubber bushings and isolato... Feb 24 2025, 02:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 07:34 PM |
