| Literati914 |
Feb 4 2025, 10:54 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,385 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I'm thinking that I don't have the vertical shift lever adjusted on the splined horizontal rod correctly.. (car is yet to be driven after restoration). It seems to take quite a lot of effort to get it all the way over to the 1/R side. It's been too long since I owned my last 914 to remember exactly how it's suppose to feel. But I do not remember it taking this much effort. So, when the lever is at rest, would you say it sits in the middle (of neutral's left to right plane) or that it favors either L or R ? I mean the middle seems logical I guess, and I probably just have it mal-adjusted.
I installed the shifter many months back always intending to revisit the subject before first start up - which is quickly approaching (IMG:style_emoticons/default/piratenanner.gif) |
| Montreal914 |
Feb 5 2025, 09:23 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,199 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
That's how I had mine adjusted too. Lever against the spring loaded stop plate would have been the 2-3 plane. Two springs setup at the shifter and it was easy to get in 1st reverse. 4 spring is quite harder.
After modifying the tail end of the shift linkage (firewall to gearbox) with the double support at the gearbox shift console and double steering U-joints, the rear mechanism was very smooth and resistanceless. Actually, this rear shift likage upgrade made the movement so easy that when pushing the level out of 1st gear, I had to "catch" it and and push it up in 2nd because the two springs would push the level all the way to the 4-5. (IMG:style_emoticons/default/driving.gif) I kept on going from 1st to 4th... This made me realize that this upgrade would benefit of a central positioning shifter design such as the Rennshift with springs on both side option. |
Literati914 Shift Lever at Rest Feb 4 2025, 10:54 PM
technicalninja Doesn't the 1/R "plane" require the ... Feb 4 2025, 11:03 PM
Literati914
Did you put two or four springs in the flange?... Feb 5 2025, 10:37 AM
rhodyguy The 3rd and 4th springs are included in the short ... Feb 5 2025, 01:02 PM
technicalninja
Did you put two or four springs in the flange... Feb 5 2025, 01:14 PM
rhodyguy Once out of R/1 the plate acts as a guide for 2/3.... Feb 5 2025, 01:34 PM
Dr Evil In my sig below is a link to my notes which includ... Feb 12 2025, 08:05 AM![]() ![]() |
Lo-Fi Version | Time is now: 25th September 2026 - 03:17 AM |
