Jgilliam914 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,370 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest ![]() |
I was digging through a storage tote and found a set of NPR 96mm pistons and cylinders.
Is there a difference between one that fits a 1.7 vs a 2.0? |
zig-n-zag |
Member ![]() ![]() Group: Members Posts: 206 Joined: 18-May 06 From: Hawaii Member No.: 6,024 ![]() |
I measured the wrist pin to the piston top for a 90mm piston and it’s 42mm. The 94mm bus piston is at 35.6mm. I assume the 93mm piston would also be 42mm. Interestingly, a Cima/Mahle forged type 1 94mm stroker piston has a pin height of 35.3mm.
The rod length center to center for the 1.7 and 1.8 is 127mm and the 2.0 rod length is 131mm. |
Lo-Fi Version | Time is now: 15th September 2025 - 04:58 PM |
