> 123 Ignition Distributor Timing Curve, Curve for carbureted 2056
SteveNMaine
post Feb 19 2025, 10:36 AM
I am looking for the basic timing curve settings for a 123 TUNE+ 4-R-V-P distributor for a dual 40 IDF carbureted 2056.
I have been all over the different forums and really looking for more specific information for my build.
Thanks.
Jack Standz
post Feb 20 2025, 01:30 AM
QUOTE(flipb @ Feb 20 2025, 12:05 AM) *
Here are some of the standard Bosch curves. I'm running 2056 with IDF 40s and I've programmed in the 050 curve; I find that it makes excellent power.
(IMG:http://www.914world.com/bbs2/uploads_offsite/rennlist.com-10752-1739984715.1.jpg)
To the OP, I'll add my current and total advance amounts we are running on our 2056, if you think it's relevant, because it's got a Mallory Unilite distributor and not a 123 distributor.
@flipb
Very interesting on the 050 advance curve (which is a distributor I ran on a VW years ago). IIRC it worked and ran well.
Questions:
1. If you've programmed in 30 degrees of total advance, where is your initial advance set at? What's your CR?
2. Are you getting any pre-ignition (pinging) with all this advance on your 2056?
SteveNMaine   123 Ignition Distributor Timing Curve   Feb 19 2025, 10:36 AM
flipb   Here are some of the standard Bosch curves. I...   Feb 19 2025, 11:05 AM
JamesM   Assuming you have the fully programable model, it ...   Feb 20 2025, 02:13 AM
930cabman   I am running an aftermarket 009, works great. I...   Feb 19 2025, 02:15 PM
VaccaRabite   I am running an aftermarket 009, works great. I...   Feb 21 2025, 06:52 AM
Jack Standz   Here are some of the standard Bosch curves. I...   Feb 20 2025, 01:30 AM
flipb   [quote name='flipb' post='3192631' date='Feb 20 2...   Feb 20 2025, 03:19 PM
Jack Standz   So why I was asking is this. If the initial advan...   Feb 20 2025, 01:43 PM
JamesM   So why I was asking is this. If the initial adva...   Feb 20 2025, 10:38 PM
914_teener   So why I was asking is this. If the initial adva...   Feb 27 2025, 01:05 PM
brant   38-44 is too much Shot for 30 depending on your a...   Feb 20 2025, 02:19 PM
flipb   Adding to the above -- for what it's worth, I...   Feb 20 2025, 03:25 PM
Jack Standz   @flipb OK, thanks for the response. Just to cl...   Feb 20 2025, 04:59 PM
flipb   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Feb 21 2025, 07:53 AM
SteveNMaine   [b]@[url=http://www.914world.com/bbs2/index.php?...   Feb 24 2025, 06:46 AM
flipb   [quote name='flipb' post='3192885' date='Feb 21 2...   Feb 24 2025, 07:34 AM
iankarr   Since every engine is different, and the benefit o...   Feb 24 2025, 09:05 AM
SteveNMaine   Since every engine is different, and the benefit ...   Feb 27 2025, 07:24 AM
SteveNMaine   Since every engine is different, and the benefit ...   Jul 3 2025, 11:11 AM
IronHillRestorations   If you have the Bluetooth version, I can email or ...   Feb 27 2025, 07:34 AM
SteveNMaine   I still have not been able to get my 2056 to start...   Jul 3 2025, 08:53 AM
IronHillRestorations   I’m going to suggest that you have installed the...   Jul 3 2025, 11:00 AM
densible1   That's exactly what happened to me , wasn...   Jul 3 2025, 11:13 AM
SteveNMaine   That's exactly what happened to me , wasn...   Jul 3 2025, 12:11 PM
McTyke   I have a switch model 123ignition on my 2258 cc en...   Oct 13 2026, 02:17 AM
emerygt350   Those curves are supposed to be identical to the m...   Oct 13 2026, 05:37 AM
- Lo-Fi Version Time is now: 13th October 2026 - 05:41 AM
