| SteveNMaine |
Feb 19 2025, 10:36 AM
Member ![]() ![]() Group: Members Posts: 94 Joined: 12-August 24 From: Maine Member No.: 28,288 Region Association: None |
I am looking for the basic timing curve settings for a 123 TUNE+ 4-R-V-P distributor for a dual 40 IDF carbureted 2056.
I have been all over the different forums and really looking for more specific information for my build. Thanks. |
| Jack Standz |
Feb 20 2025, 01:30 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 950 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Here are some of the standard Bosch curves. I'm running 2056 with IDF 40s and I've programmed in the 050 curve; I find that it makes excellent power. (IMG:http://www.914world.com/bbs2/uploads_offsite/rennlist.com-10752-1739984715.1.jpg) To the OP, I'll add my current and total advance amounts we are running on our 2056, if you think it's relevant, because it's got a Mallory Unilite distributor and not a 123 distributor. @flipb Very interesting on the 050 advance curve (which is a distributor I ran on a VW years ago). IIRC it worked and ran well. Questions: 1. If you've programmed in 30 degrees of total advance, where is your initial advance set at? What's your CR? 2. Are you getting any pre-ignition (pinging) with all this advance on your 2056? |
| flipb |
Feb 20 2025, 03:19 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,899 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region
Here are some of the standard Bosch curves. I'm running 2056 with IDF 40s and I've programmed in the 050 curve; I find that it makes excellent power. To the OP, I'll add my current and total advance amounts we are running on our 2056, if you think it's relevant, because it's got a Mallory Unilite distributor and not a 123 distributor. @flipb Very interesting on the 050 advance curve (which is a distributor I ran on a VW years ago). IIRC it worked and ran well. Questions: 1. If you've programmed in 30 degrees of total advance, where is your initial advance set at? What's your CR? 2. Are you getting any pre-ignition (pinging) with all this advance on your 2056? Here's the curve as I programmed it into the 1-2-3 Distributor. I don't remember my CR, would need to look at the engine build notes. It's not super high. Have not noticed any pinging but I am running premium fuel. |
SteveNMaine 123 Ignition Distributor Timing Curve Feb 19 2025, 10:36 AM
flipb Here are some of the standard Bosch curves. I... Feb 19 2025, 11:05 AM
JamesM Assuming you have the fully programable model, it ... Feb 20 2025, 02:13 AM
930cabman I am running an aftermarket 009, works great. I... Feb 19 2025, 02:15 PM
VaccaRabite
I am running an aftermarket 009, works great. I... Feb 21 2025, 06:52 AM
Jack Standz So why I was asking is this. If the initial advan... Feb 20 2025, 01:43 PM
JamesM
So why I was asking is this. If the initial adva... Feb 20 2025, 10:38 PM
914_teener
So why I was asking is this. If the initial adva... Feb 27 2025, 01:05 PM
brant 38-44 is too much
Shot for 30 depending on your a... Feb 20 2025, 02:19 PM
flipb Adding to the above -- for what it's worth, I... Feb 20 2025, 03:25 PM
Jack Standz @flipb
OK, thanks for the response.
Just to cl... Feb 20 2025, 04:59 PM
flipb
[b]@[url=http://www.914world.com/bbs2/index.php?s... Feb 21 2025, 07:53 AM
SteveNMaine
[b]@[url=http://www.914world.com/bbs2/index.php?... Feb 24 2025, 06:46 AM
flipb
[quote name='flipb' post='3192885' date='Feb 21 2... Feb 24 2025, 07:34 AM
iankarr Since every engine is different, and the benefit o... Feb 24 2025, 09:05 AM
SteveNMaine
Since every engine is different, and the benefit ... Feb 27 2025, 07:24 AM
SteveNMaine
Since every engine is different, and the benefit ... Jul 3 2025, 11:11 AM
IronHillRestorations If you have the Bluetooth version, I can email or ... Feb 27 2025, 07:34 AM
SteveNMaine I still have not been able to get my 2056 to start... Jul 3 2025, 08:53 AM
IronHillRestorations I’m going to suggest that you have installed the... Jul 3 2025, 11:00 AM
densible1 That's exactly what happened to me , wasn... Jul 3 2025, 11:13 AM
SteveNMaine
That's exactly what happened to me , wasn... Jul 3 2025, 12:11 PM
McTyke I have a switch model 123ignition on my 2258 cc en... Oct 13 2026, 02:17 AM
emerygt350 Those curves are supposed to be identical to the m... Oct 13 2026, 05:37 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th October 2026 - 05:41 AM |
