| echocanyons |
Feb 2 2025, 01:21 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,118 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California
I’m swapping the struts/brakes from a 75 Carrera to a 75 914.
The hole that the rubber brake line at the strut end doesn’t seem to be large enough to support my existing rubber brake line. Also, there looks to be two different support clips. Could someone educate me to the difference and what I should be using to connect my brake lines to a 1975 strut. Attached thumbnail(s) |
| echocanyons |
Feb 23 2025, 11:50 AM
Thank you all.
Eric, that is great info. I appreciate your effort to put that together. I am trying to add the 911 struts so I will look for the lines that go with them. |
echocanyons Brake line differences - support through strut Feb 2 2025, 01:21 PM
bdstone914 The hole size should be the same in both struts. ... Feb 2 2025, 02:31 PM
914Sixer 73-76 use this clip, It is thin, early cars and 9... Feb 2 2025, 05:35 PM
willieg When I put some 911 brake parts on my 74 914, I fo... Feb 3 2025, 03:48 PM
iankarr @eric_shea Feb 4 2025, 02:00 AM
Montreal914 ^^^ This!
I contacted Eric Shea at PMB and he... Feb 4 2025, 09:23 AM
Eric_Shea Hey Kelly,
Early (70-72) cars used a spring clip ... Feb 5 2025, 02:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th September 2026 - 08:53 AM |
