| SteveNMaine |
Feb 19 2025, 10:36 AM
Member ![]() ![]() Group: Members Posts: 94 Joined: 12-August 24 From: Maine Member No.: 28,288 Region Association: None |
I am looking for the basic timing curve settings for a 123 TUNE+ 4-R-V-P distributor for a dual 40 IDF carbureted 2056.
I have been all over the different forums and really looking for more specific information for my build. Thanks. |
| Jack Standz |
Feb 20 2025, 04:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 950 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
@flipb
OK, thanks for the response. Just to clarify, you're saying that you're firing the sparks in your 2056 at TDC (top dead center) from 0 to 1,000 RPMs? That seems way too late. How is low RPM performance? |
| flipb |
Feb 21 2025, 07:53 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,899 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region
@flipb OK, thanks for the response. Just to clarify, you're saying that you're firing the sparks in your 2056 at TDC (top dead center) from 0 to 1,000 RPMs? That seems way too late. How is low RPM performance? As I understand it, the 1-2-3 software draws in the section of the advance curve between the points that I programmed in. So linearly, since I have zero advance at 500rpm and 5 degrees at 1000rpm, it should look like: 500rpm - 0 degrees 600rpm - 1 degree 700rpm - 2 degrees 800rpm - 3 degrees 900rpm - 4 degrees 1000rpm - 5 degrees Since it idles around 900rpm, it's never really running with spark at TDC except perhaps during cranking. Idles fine. |
| SteveNMaine |
Feb 24 2025, 06:46 AM
@flipb OK, thanks for the response. Just to clarify, you're saying that you're firing the sparks in your 2056 at TDC (top dead center) from 0 to 1,000 RPMs? That seems way too late. How is low RPM performance? As I understand it, the 1-2-3 software draws in the section of the advance curve between the points that I programmed in. So linearly, since I have zero advance at 500rpm and 5 degrees at 1000rpm, it should look like: 500rpm - 0 degrees 600rpm - 1 degree 700rpm - 2 degrees 800rpm - 3 degrees 900rpm - 4 degrees 1000rpm - 5 degrees Since it idles around 900rpm, it's never really running with spark at TDC except perhaps during cranking. Idles fine. So, if I set the 123 timing from 10 @ 950 to 28 @ 3500 it will fill in equal increments of advance across the RPM range? |
| flipb |
Feb 24 2025, 07:34 AM
@flipb OK, thanks for the response. Just to clarify, you're saying that you're firing the sparks in your 2056 at TDC (top dead center) from 0 to 1,000 RPMs? That seems way too late. How is low RPM performance? As I understand it, the 1-2-3 software draws in the section of the advance curve between the points that I programmed in. So linearly, since I have zero advance at 500rpm and 5 degrees at 1000rpm, it should look like: 500rpm - 0 degrees 600rpm - 1 degree 700rpm - 2 degrees 800rpm - 3 degrees 900rpm - 4 degrees 1000rpm - 5 degrees Since it idles around 900rpm, it's never really running with spark at TDC except perhaps during cranking. Idles fine. So, if I set the 123 timing from 10 @ 950 to 28 @ 3500 it will fill in equal increments of advance across the RPM range? Yes, I believe it would draw a linear slope between any two points. See the chart in my post above -- that is right out of the 1-2-3 app. (I realize that the Bosch 050 Advance Curve is pretty much linear so I could've saved myself some time by just programming in 1000RPM and 3000RPM but I guess I was still learning at that point.) |
SteveNMaine 123 Ignition Distributor Timing Curve Feb 19 2025, 10:36 AM
flipb Here are some of the standard Bosch curves. I... Feb 19 2025, 11:05 AM
JamesM Assuming you have the fully programable model, it ... Feb 20 2025, 02:13 AM
930cabman I am running an aftermarket 009, works great. I... Feb 19 2025, 02:15 PM
VaccaRabite
I am running an aftermarket 009, works great. I... Feb 21 2025, 06:52 AM
Jack Standz
Here are some of the standard Bosch curves. I... Feb 20 2025, 01:30 AM
flipb
[quote name='flipb' post='3192631' date='Feb 20 2... Feb 20 2025, 03:19 PM
Jack Standz So why I was asking is this. If the initial advan... Feb 20 2025, 01:43 PM
JamesM
So why I was asking is this. If the initial adva... Feb 20 2025, 10:38 PM
914_teener
So why I was asking is this. If the initial adva... Feb 27 2025, 01:05 PM
brant 38-44 is too much
Shot for 30 depending on your a... Feb 20 2025, 02:19 PM
flipb Adding to the above -- for what it's worth, I... Feb 20 2025, 03:25 PM
iankarr Since every engine is different, and the benefit o... Feb 24 2025, 09:05 AM
SteveNMaine
Since every engine is different, and the benefit ... Feb 27 2025, 07:24 AM
SteveNMaine
Since every engine is different, and the benefit ... Jul 3 2025, 11:11 AM
IronHillRestorations If you have the Bluetooth version, I can email or ... Feb 27 2025, 07:34 AM
SteveNMaine I still have not been able to get my 2056 to start... Jul 3 2025, 08:53 AM
IronHillRestorations I’m going to suggest that you have installed the... Jul 3 2025, 11:00 AM
densible1 That's exactly what happened to me , wasn... Jul 3 2025, 11:13 AM
SteveNMaine
That's exactly what happened to me , wasn... Jul 3 2025, 12:11 PM
McTyke I have a switch model 123ignition on my 2258 cc en... Oct 13 2026, 02:17 AM
emerygt350 Those curves are supposed to be identical to the m... Oct 13 2026, 05:37 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th October 2026 - 05:40 AM |
