| L-Jet914 |
Feb 25 2025, 11:35 PM
Member ![]() ![]() Group: Members Posts: 424 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I was installing my new ignition and FI harnesses today and I decided to look back at the vacuum hose routing diagram on Jeff Bowlsby's website. I knew my vacuum hose routing had been modified by whatever technician worked on my father's 74 914 1.8 years ago. I noticed that they teed the vacuum retard side of the vacuum advance into ported vacuum off of the intake plenum. According to the vacuum routing hose diagram, it's supposed to be connected to the rear port of the throttle body (which only gets vacuum after the throttle plate moves off idle). Would there be any reason the technician did this? I will end up rerouting the vacuum hose to the proper location. I'm just curious as to why it was modified for whatever reason. So would my 74 1.8 be considered a early or late 1.8? According to the late diagram and the throttle body that is in the car, the hose should route to the front port instead of the rear port.
The part number on the throttle body in the car 022133067C which fits either a Super Beetle 75-79, 76-83 Bus, or 83-84 Vanagon (two port t-body). According to the PET on AA's website shows two different throttle bodies 022133062L or 022133062S for California spec 1.8L 914s. The Porsche PET does not list a throttle body part number for the 1.8, only the 1.7 and 2.0s. Curious as to why someone would put the wrong part number throttle body on my 914, though it does have the 3 pin throttle position sensor. Port setup would be indicative of late 74 because the required port (front of throttle body pointing toward front of vehicle) is behind the throttle plate. Attached thumbnail(s) Attached image(s)
| Fazasport |
Feb 27 2025, 06:17 AM
Newbie ![]() Group: Members Posts: 13 Joined: 7-November 23 From: Tallahassee FL Member No.: 27,713 Region Association: South East States |
I have a 1976 914 2.0 with D-Jet and no modifications. My throttle body has one vaccum port and my distributor has two nipples for vaccum lines. One nipple is on the front of the vaccum canister and the other is on the rear.
My question is which port on the vaccum canister does the line from the throttle body go to, front or rear and what to do with the other port on the canister. Currently the port on the front of the canister has a 3" section of vaccum hose attached with a screw inserted into the hose to cap it off. Thanks for your help. John Sipay Tallahassee, FL |
L-Jet914 vacuum hose routing question Feb 25 2025, 11:35 PM
wonkipop the authorative hose diagrams are here mate. bott... Feb 26 2025, 04:37 AM
L-Jet914
the authorative hose diagrams are here mate. bot... Feb 27 2025, 10:21 PM
JeffBowlsby Michael is the L-Jet MAN. That diagram on my site... Feb 26 2025, 09:09 AM
StarBear
Michael is the L-Jet MAN. That diagram on my sit... Feb 26 2025, 02:04 PM
wonkipop
Michael is the L-Jet MAN. That diagram on my si... Feb 26 2025, 02:39 PM
wonkipop @L-Jet914
i looked up the PET i have on file and... Feb 26 2025, 02:12 PM
wonkipop @L-Jet914
if you think i have mixed up the let... Feb 26 2025, 02:29 PM
wonkipop for your interest @L-Jet914 .
here is an image ... Feb 26 2025, 03:52 PM
wonkipop
I have a 1976 914 2.0 with D-Jet and no modificat... Feb 27 2025, 06:21 PM
wonkipop @L-Jet914
david - that throttle body looks ident... Feb 28 2025, 10:57 AM
L-Jet914
[b]@[url=http://www.914world.com/bbs2/index.php?s... Feb 28 2025, 07:57 PM
Rob-O Beyond all the hooking up of vacuum lines, the cha... Mar 3 2025, 07:35 AM
wonkipop
Beyond all the hooking up of vacuum lines, the ch... Mar 3 2025, 05:53 PM
L-Jet914 Sorry for opening up a can of worms haha. When I r... Mar 4 2025, 12:35 AM
emerygt350
Sorry for opening up a can of worms haha. When I ... Mar 4 2025, 08:39 AM
L-Jet914
Sorry for opening up a can of worms haha. When I... Mar 4 2025, 04:39 PM
wonkipop
Sorry for opening up a can of worms haha. When I... Mar 5 2025, 04:34 AM
L-Jet914
Sorry for opening up a can of worms haha. When I... Mar 9 2025, 11:16 PM
emerygt350 Maybe my next CAD project. Mar 4 2025, 05:47 PM
L-Jet914
Oooo. That would be a... Mar 4 2025, 05:54 PM
emerygt350 I think I might have to try this project. Mar 4 2025, 07:25 PM
emerygt350 Yes, there is definitely that "driving a lazy... Mar 5 2025, 05:25 AM![]() ![]() |
Lo-Fi Version | Time is now: 25th September 2026 - 04:24 AM |
