> Recommendation on fuel pressure regulator for return line on dual carb
Tdskip
post Apr 13 2024, 04:36 PM
Hi folks end hope everybody’s having a decent Saturday.
I need to button up another project car that was previously (long time ago and original engine long gone) a fuel injection car so it’s got the return line like they all do.
It looks like many of you like to use a pressure regulator in the return line, rather than simply capping it off, and I was wondering if there’s a specific regulator that you would recommend or if a Holley rotary dial to select pressure unit is fine to use.
Thanks!
Retroracer
post Feb 27 2025, 03:14 PM
Check out the pic as installed on my car. Think this is option D in your drawing, briefly:
- the pump inlet and tank return are the connections on the LHS
- the low pressure side gauge and adjustment (brass fitment) are on the top side
- the two outputs (one for each TIN40) are on the side facing the camera
Hope this helps,
- Tony
friethmiller
post Feb 27 2025, 03:50 PM
QUOTE(Retroracer @ Feb 27 2025, 03:14 PM) *
Hope this helps,
- Tony
Yes, it does. Thank you for the photo/description.
~Fred
Tdskip   Recommendation on fuel pressure regulator for return line on dual carb   Apr 13 2024, 04:36 PM
brant   Anything adjustable should work I’ve used a rot...   Apr 14 2024, 08:11 AM
mate914   Hi folks end hope everybody’s having a decent S...   Apr 14 2024, 08:41 AM
914werke   Id suggest the Holly unit its inexpensive, uses st...   Apr 14 2024, 01:18 PM
Tdskip   Thanks for all the feedback. Not really sure yet ...   Apr 15 2024, 09:31 AM
theer   I have the Holly as well, combined with a low pres...   Apr 16 2024, 01:56 PM
technicalninja   Be careful here! What many have alluded to ar...   Apr 16 2024, 02:35 PM
stownsen914   There are a few different kinds of regulators out ...   Apr 17 2024, 10:01 AM
technicalninja   Modern EFI no longer has return lines. Pretty muc...   Apr 17 2024, 10:14 AM
rfinegan   I am using this regulator with the stock fuel pump...   Apr 17 2024, 10:23 AM
rhodyguy   Don’t forget the FP gauge and 2 more shouldered ...   Apr 17 2024, 11:38 AM
Tdskip   Thanks for the discussion and all the consideratio...   Apr 17 2024, 05:28 PM
stownsen914   Interesting points about how it's done on mode...   Apr 18 2024, 06:36 AM
friethmiller   Question: why can't I find a by-pass fuel regu...   Feb 26 2025, 02:56 PM
Retroracer   Question: why can't I find a by-pass fuel reg...   Feb 26 2025, 03:34 PM
friethmiller   [url=https://patrickmotorsports.com/products/fuep...   Feb 27 2025, 06:49 AM
Retroracer   Check out the pic as installed on my car. Think t...   Feb 27 2025, 03:14 PM
friethmiller   - the pump inlet and tank return are the connect...   Feb 27 2025, 03:50 PM
- Lo-Fi Version Time is now: 15th January 2026 - 04:23 AM
