Literati914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,020 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
1.7 that was supposedly rebuilt just before I purchased the project approx 7 year ago. Never started before. D-jet. Electronic unit replacing the orig. points. Engine currently installed in the engine bay. I primed the oil system the other day and now the idiot light will go out after a couple seconds of cranking.
About the 3rd time or so of trying to start the engine.. it seemed to have lit, it only lasted about 2 seconds (IMG:style_emoticons/default/biggrin.gif) but it felt good, like it wouldn’t take long. Unfortunately it’s not done much but turn over strong since then. Sometimes it’ll do a little shuffle like it’s gonna start, but no. I checked the plugs and they have spark, they seemed slightly damp at the electrodes, I also pulled the little small extra bolt on the fuel rail at the driver’s side to see if fuel was making it to the injectors and yes it is apparently. This 1.7 has a fan with 2 markings… a “0” and an “|” …. Haynes says it’s supposed to have 3 markings but mine does not. If I insert a screwdriver into #1 cylinder and manually bring the fan around via a wrench on the alternator bolt (pulling it towards me from the driver’s side).. I come to the “|” first, before the piston is completely at the top. So I’m speculating that “|” is 5degrees btdc . And this is the mark I’m using to set my distributor. Does that sound right? Attached thumbnail(s) ![]() |
Literati914 |
Does it start with starting fluid? If the contacts in the dizzy are not working the injectors will not fire. Doesn't the fact that I'm getting spark indicate that the contacts in the dizzy is working? (Not being a smart@*#, just asking).. Also - YES I got it to start with starting fluid - doesn't this fact also show I'm at TBC on the compression stroke (again, I ask only to verify my understanding) |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,193 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Doesn't the fact that I'm getting spark indicate that the contacts in the dizzy is working? (Not being a smart@*#, just asking).. Also - YES I got it to start with starting fluid - doesn't this fact also show I'm at TBC on the compression stroke (again, I ask only to verify my understanding) The DJET system works off of the trigger points in the distributor. The firing of spark plugs is independent of DJET and done with the standard points/electronic ignition. That you started it with starting fluid says there's no fuel in it. Check the trigger points in the distributor. The trigger points is what the DJET uses to indicate the engine is turning. This will also start the fuel pump up too. |
Lo-Fi Version | Time is now: 15th July 2025 - 01:18 PM |
