| DeWitt |
Mar 4 2025, 11:12 AM
Newbie ![]() Group: Members Posts: 13 Joined: 25-August 24 From: Lancaster County, PA Member No.: 28,309 Region Association: North East States |
I have a MaxJax lift in my hobby shop. When I had it installed (I went with pro installers), I had them put anchors in for two different widths. I've only ever used the narrow width, with my very narrow MG TD, but just recently I bought a very nice 1973 914 2.0 from a Porsche mechanic in Virginia. Today, I installed the post in the wide position, and it's just right for the 914! This photo is of the car in the highest lift position.
![]() I used the standard pads without the lift extensions, and added an ordinary hockey puck at each location to make sure the lift arms didn't touch the side skirts. I carefully aligned the pads and pucks under the four lift points - the round dimples with a hole in the center. Here are photos of front and rear points. ![]() ![]() I measured the distance between the front mounting bolt holes on the two posts, in case someone else is installing a MaxJax for 914 use. It was just shy of 119 inches in my setup. Here's a photo of that also, so you can see where I was measuring from. ![]() |
VaccaRabite Hey DeWitt :wttc:
I live down the road from you ... Mar 4 2025, 06:27 PM
DeWitt
Hey DeWitt :wttc:
I live down the road from you... Mar 5 2025, 09:38 AM
worn
Hey DeWitt :wttc:
I live down the road from you... Mar 5 2025, 08:03 PM
Mikey914 I did twin Busch. As far as anchors go the enginee... Mar 4 2025, 07:44 PM
DeWitt
I did twin Busch. As far as anchors go the engine... Mar 5 2025, 09:27 AM
914werke I chose the MaxJax for two reasons: low ceiling ... Mar 5 2025, 09:43 AM
DeWitt
I chose the MaxJax for two reasons: low ceiling... Mar 7 2025, 03:52 PM
North Coast Jim
I have a MaxJax lift in my hobby shop. When I had... Mar 6 2025, 10:23 AM
DeWitt
Those locks are there for a safety reason. Bette... Mar 7 2025, 03:55 PM
Spoke
Those locks are there for a safety reason. Bett... Mar 7 2025, 04:05 PM
[quote name='North Coast Jim' post='3195041' dat... Mar 8 2025, 04:49 PM
mb911
[quote name='Spoke' post='3195259' date='Mar 7 20... Mar 8 2025, 06:35 PM
76-914 Those donuts aren't designed for lifting. They... Mar 7 2025, 04:02 PM
windforfun
Those donuts aren't designed for lifting. The... Mar 7 2025, 05:24 PM
914werke [quote name='914werke' post='3194882' date='Mar 5... Mar 7 2025, 05:10 PM
Spoke I can lift my 914 or 911 about 3 ft off the ground... Mar 8 2025, 02:22 PM
windforfun
I can lift my 914 or 911 about 3 ft off the groun... Mar 8 2025, 04:46 PM
VaccaRabite
I can lift my 914 or 911 about 3 ft off the grou... Mar 12 2025, 05:30 AM
windforfun Wow!!!
:drooley: :drooley: :droole... Mar 8 2025, 06:57 PM
Tonyooc How tall is the lift? I only have 9' ceiling Mar 10 2025, 07:02 PM
VaccaRabite
... Mar 12 2025, 05:28 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th September 2026 - 07:05 PM |
