| jim_hoyland |
Dec 26 2024, 04:52 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,041 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
There are 4 Allen Head bolts holding the steering column to the frame above.
I need to loosen those bolts to lower steering column an inch; reason is the tach in my Getty dash won’t clear the steering column shroud. So, I’m attempting to lower the column to get room so the tach can be pulled out. But, the Allen head bolts are really tight; no arm strength was going to budge them. And, I don’t want to ruin the Allen bolt heads What is the solution to loosening those bolts ? |
| jim_hoyland |
Mar 7 2025, 05:13 PM
Update: Had to use a cheater them to loosen. Six complete turns gives enough room to access my tach. Never size a must !
jim_hoyland Steering Column Bolts Dec 26 2024, 04:52 PM
JeffBowlsby A bigger lever arm on that Allen wrench. Maybe so... Dec 26 2024, 04:54 PM
SirAndy You don't need to lower the steering column.
... Dec 26 2024, 05:08 PM
windforfun It's time for a pipe. And not the kind you sm... Dec 26 2024, 05:14 PM
technicalninja :agree:
SirAndy has the correct answer!
But... Dec 26 2024, 05:18 PM
sixnotfour Hope you get a solution.. saw your message late l... Dec 26 2024, 06:13 PM
jim_hoyland thanks; that gives some new ideas,
I have the soc... Dec 26 2024, 06:58 PM
Root_Werks Careful with the impact tool. Maybe try the rachet... Dec 26 2024, 07:04 PM
jim_hoyland
Careful with the impact tool. Maybe try the rache... Dec 26 2024, 07:27 PM
Root_Werks Yikes, those are really in there. Welp, impact it... Dec 27 2024, 12:48 PM
technicalninja If I can get to the threaded section, I'll hos... Dec 27 2024, 01:05 PM
rfinegan A hand impact/ hammer with Allen socket and the sh... Dec 27 2024, 02:37 PM
jim_hoyland
A hand impact/ hammer with Allen socket and the s... Dec 27 2024, 05:49 PM
sixnotfour :trophy: :driving: Mar 7 2025, 08:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:37 AM |
