| DC_neun_vierzehn |
Mar 8 2025, 12:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 677 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
I've searched and found a lot of 914 World threads on this topic. Most people were disappointed with their DIY results using kits from Auto Atlanta, 914 Rubber, AAA Upholster, etc. Seems like the poor results are not from the kits, but due to the skill level needed for the job (reupholstering the backpad requires more skill than reupholstering the seats). Even Ian Karr (AKA Mr. DIY) said it's a job for the pros in one of the posts.
So my questions are ... 1. I'm going to look locally ... do I need to find a speciality auto auto upholstery shop (one that specializes in classic cars or custom work) or should just about any most be able to do this job well? 2. Should I supply them the materials (e.g., 914 Rubber's vinyl kit and plastic core backing) or let them handle that? 3. What would be a fair price to pay locally (with and without me supplying the materials)? I called Autos International in Escondido, CA per George's recommendation and they quoted me $1,500. That's way beyond my budget. |
| worn |
Mar 8 2025, 12:21 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,648 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
I've searched and found a lot of 914 World threads on this topic. Most people were disappointed with their DIY results using kits from Auto Atlanta, 914 Rubber, AAA Upholster, etc. Seems like the poor results are not from the kits, but due to the skill level needed for the job (reupholstering the backpad requires more skill than reupholstering the seats). Even Ian Karr (AKA Mr. DIY) said it's a job for the pros in one of the posts. So my questions are ... 1. I'm going to look locally ... do I need to find a speciality auto auto upholstery shop (one that specializes in classic cars or custom work) or should just about any most be able to do this job well? 2. Should I supply them the materials (e.g., 914 Rubber's vinyl kit and plastic core backing) or let them handle that? 3. What would be a fair price to pay locally (with and without me supplying the materials)? I called Autos International in Escondido, CA per George's recommendation and they quoted me $1,500. That's way beyond my budget. I am going to say this is best done DIY. You buy the fabric by the yard and cut to match the old pieces. You have to pull out the old seams to get the individual pieces. You can mark them on the back to help you remeber how they fit together. Some sewing is required, but I bet any alteration shop could do it if you don't have a machine. Then you glue the fabric to the masonite. I have used fiberglass to reinforce old masonite pressboard and that works well and protects it from water. Dry run the fitting of the fabric to the solid pieces. I wish that I had: 1. Put a thin laayer of fabric backed foam on the solid board to mask imperfections that telegraph through the vinyl. 2. Used a bit more glue. It is going to be contact cement and that has the problem of needing to dry just the right amount of time before bringing pieces together. Then they fall in love with each other instantly. To avoid getting it wrong, I put strips of acrdboard between the pieces, position them and then sequentially pull out the cardboard. If this sounds too dificult, I hope that you find the right place. |
DC_neun_vierzehn Backpad Reupholstering Mar 8 2025, 12:03 PM
DC_neun_vierzehn Still seeking others' input on my original pos... Mar 13 2025, 04:14 PM
Shivers I had a small shop install a kit for the back pad.... Mar 13 2025, 04:31 PM
Root_Werks I just went through trying to redo my backpad:
Tw... Mar 13 2025, 05:02 PM
mepstein Use weldwood contact cement. It doesn’t let go. Mar 13 2025, 05:17 PM
914werke I've searched and found a lot of 914 World th... Mar 13 2025, 08:23 PM
Geezer914 I covered the back panel with black perlon carpet. Mar 14 2025, 12:08 PM
GeorgeKopf
I covered the back panel with black perlon carpet... Sep 19 2026, 08:29 AM
Shredhead I started trying to do it myself using the 914Rubb... Mar 14 2025, 12:24 PM
Root_Werks
I started trying to do it myself using the 914Rub... Mar 14 2025, 12:46 PM
StratPlayer I would try PMB to get that backpad redone. Did a... Mar 14 2025, 12:53 PM
76-914 The main problem that I had with the 914rubber kit... Mar 14 2025, 08:50 PM
dr914@autoatlanta.com absolutely the skill level. Our kits fit perfectly... Mar 15 2025, 11:03 AM
DC_neun_vierzehn Hey George, when I called you last year, you told ... Mar 16 2025, 12:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th September 2026 - 04:45 PM |
