| DeWitt |
Mar 4 2025, 11:12 AM
Newbie ![]() Group: Members Posts: 13 Joined: 25-August 24 From: Lancaster County, PA Member No.: 28,309 Region Association: North East States |
I have a MaxJax lift in my hobby shop. When I had it installed (I went with pro installers), I had them put anchors in for two different widths. I've only ever used the narrow width, with my very narrow MG TD, but just recently I bought a very nice 1973 914 2.0 from a Porsche mechanic in Virginia. Today, I installed the post in the wide position, and it's just right for the 914! This photo is of the car in the highest lift position.
![]() I used the standard pads without the lift extensions, and added an ordinary hockey puck at each location to make sure the lift arms didn't touch the side skirts. I carefully aligned the pads and pucks under the four lift points - the round dimples with a hole in the center. Here are photos of front and rear points. ![]() ![]() I measured the distance between the front mounting bolt holes on the two posts, in case someone else is installing a MaxJax for 914 use. It was just shy of 119 inches in my setup. Here's a photo of that also, so you can see where I was measuring from. ![]() |
| North Coast Jim |
Mar 6 2025, 10:23 AM
Member ![]() ![]() Group: Members Posts: 348 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region
I have a MaxJax lift in my hobby shop. When I had it installed (I went with pro installers), I had them put anchors in for two different widths. I've only ever used the narrow width, with my very narrow MG TD, but just recently I bought a very nice 1973 914 2.0 from a Porsche mechanic in Virginia. Today, I installed the post in the wide position, and it's just right for the 914! This photo is of the car in the highest lift position. ![]() I used the standard pads without the lift extensions, and added an ordinary hockey puck at each location to make sure the lift arms didn't touch the side skirts. I carefully aligned the pads and pucks under the four lift points - the round dimples with a hole in the center. Here are photos of front and rear points. ![]() ![]() I measured the distance between the front mounting bolt holes on the two posts, in case someone else is installing a MaxJax for 914 use. It was just shy of 119 inches in my setup. Here's a photo of that also, so you can see where I was measuring from. ![]() Those locks are there for a safety reason. Better use them. |
| DeWitt |
Mar 7 2025, 03:55 PM
Those locks are there for a safety reason. Better use them. Hi Jim, I definitely use the position locks, every time! In fact, I settle the car onto the locks to take pressure off the lift hydraulics, since the car can be up for days at a time while I'm working on it. |
| Spoke |
Mar 7 2025, 04:05 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,429 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Those locks are there for a safety reason. Better use them. Hi Jim, I definitely use the position locks, every time! In fact, I settle the car onto the locks to take pressure off the lift hydraulics, since the car can be up for days at a time while I'm working on it. (IMG:style_emoticons/default/agree.gif) @DeWitt The directions say the locks must be used. What I couldn't find in the instructions or online is how much torque to tighten the floor bolts with. I've been using 50FT-LB. |
| mepstein |
Mar 8 2025, 04:49 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,919 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Those locks are there for a safety reason. Better use them. Hi Jim, I definitely use the position locks, every time! In fact, I settle the car onto the locks to take pressure off the lift hydraulics, since the car can be up for days at a time while I'm working on it. (IMG:style_emoticons/default/agree.gif) @DeWitt The directions say the locks must be used. What I couldn't find in the instructions or online is how much torque to tighten the floor bolts with. I've been using 50FT-LB. I think 50 is right in the ballpark. I used epoxy anchors (per @mb911 suggestion) I’m very happy with the lift. |
DeWitt 914 on MaxJax Lift Mar 4 2025, 11:12 AM
VaccaRabite Hey DeWitt :wttc:
I live down the road from you ... Mar 4 2025, 06:27 PM
DeWitt
Hey DeWitt :wttc:
I live down the road from you... Mar 5 2025, 09:38 AM
worn
Hey DeWitt :wttc:
I live down the road from you... Mar 5 2025, 08:03 PM
Mikey914 I did twin Busch. As far as anchors go the enginee... Mar 4 2025, 07:44 PM
DeWitt
I did twin Busch. As far as anchors go the engine... Mar 5 2025, 09:27 AM
914werke I chose the MaxJax for two reasons: low ceiling ... Mar 5 2025, 09:43 AM
DeWitt
I chose the MaxJax for two reasons: low ceiling... Mar 7 2025, 03:52 PM
mb911
[quote name='Spoke' post='3195259' date='Mar 7 20... Mar 8 2025, 06:35 PM
76-914 Those donuts aren't designed for lifting. They... Mar 7 2025, 04:02 PM
windforfun
Those donuts aren't designed for lifting. The... Mar 7 2025, 05:24 PM
914werke [quote name='914werke' post='3194882' date='Mar 5... Mar 7 2025, 05:10 PM
Spoke I can lift my 914 or 911 about 3 ft off the ground... Mar 8 2025, 02:22 PM
windforfun
I can lift my 914 or 911 about 3 ft off the groun... Mar 8 2025, 04:46 PM
VaccaRabite
I can lift my 914 or 911 about 3 ft off the grou... Mar 12 2025, 05:30 AM
windforfun Wow!!!
:drooley: :drooley: :droole... Mar 8 2025, 06:57 PM
Tonyooc How tall is the lift? I only have 9' ceiling Mar 10 2025, 07:02 PM
VaccaRabite
... Mar 12 2025, 05:28 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th September 2026 - 07:07 PM |
