> 914 on MaxJax Lift, Description and photos of 914 on MaxJax lift
DeWitt
post Mar 4 2025, 11:12 AM
I have a MaxJax lift in my hobby shop. When I had it installed (I went with pro installers), I had them put anchors in for two different widths. I've only ever used the narrow width, with my very narrow MG TD, but just recently I bought a very nice 1973 914 2.0 from a Porsche mechanic in Virginia. Today, I installed the post in the wide position, and it's just right for the 914! This photo is of the car in the highest lift position.
I used the standard pads without the lift extensions, and added an ordinary hockey puck at each location to make sure the lift arms didn't touch the side skirts. I carefully aligned the pads and pucks under the four lift points - the round dimples with a hole in the center. Here are photos of front and rear points.
I measured the distance between the front mounting bolt holes on the two posts, in case someone else is installing a MaxJax for 914 use. It was just shy of 119 inches in my setup. Here's a photo of that also, so you can see where I was measuring from.
windforfun
post Mar 8 2025, 06:57 PM
Wow!!!
(IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/drooley.gif)
DeWitt   914 on MaxJax Lift   Mar 4 2025, 11:12 AM
VaccaRabite   Hey DeWitt :wttc: I live down the road from you ...   Mar 4 2025, 06:27 PM
DeWitt   Hey DeWitt :wttc: I live down the road from you...   Mar 5 2025, 09:38 AM
worn   Hey DeWitt :wttc: I live down the road from you...   Mar 5 2025, 08:03 PM
Mikey914   I did twin Busch. As far as anchors go the enginee...   Mar 4 2025, 07:44 PM
DeWitt   I did twin Busch. As far as anchors go the engine...   Mar 5 2025, 09:27 AM
914werke   I chose the MaxJax for two reasons: low ceiling ...   Mar 5 2025, 09:43 AM
DeWitt   I chose the MaxJax for two reasons: low ceiling...   Mar 7 2025, 03:52 PM
North Coast Jim   I have a MaxJax lift in my hobby shop. When I had...   Mar 6 2025, 10:23 AM
DeWitt   Those locks are there for a safety reason. Bette...   Mar 7 2025, 03:55 PM
Spoke   Those locks are there for a safety reason. Bett...   Mar 7 2025, 04:05 PM
mepstein   [quote name='North Coast Jim' post='3195041' dat...   Mar 8 2025, 04:49 PM
mb911   [quote name='Spoke' post='3195259' date='Mar 7 20...   Mar 8 2025, 06:35 PM
76-914   Those donuts aren't designed for lifting. They...   Mar 7 2025, 04:02 PM
windforfun   Those donuts aren't designed for lifting. The...   Mar 7 2025, 05:24 PM
914werke   [quote name='914werke' post='3194882' date='Mar 5...   Mar 7 2025, 05:10 PM
Spoke   I can lift my 914 or 911 about 3 ft off the ground...   Mar 8 2025, 02:22 PM
windforfun   I can lift my 914 or 911 about 3 ft off the groun...   Mar 8 2025, 04:46 PM
VaccaRabite   I can lift my 914 or 911 about 3 ft off the grou...   Mar 12 2025, 05:30 AM
windforfun   Wow!!! :drooley: :drooley: :droole...   Mar 8 2025, 06:57 PM
Tonyooc   How tall is the lift? I only have 9' ceiling   Mar 10 2025, 07:02 PM
VaccaRabite   How tall is the lift? I only have 9' ceiling ...   Mar 12 2025, 05:28 AM
- Lo-Fi Version Time is now: 24th September 2026 - 07:07 PM
