> Squeal... ugh., Alternator bearing?
emerygt350
post Mar 12 2025, 06:27 AM
Got a squeal. It started last year, and I thought "oh, maybe just the belt". Belt is new, tightening it didn't help. Kinda goes away after the engine is hot (haven't been able to test that too much). Alternator works great. Starts to squeal as you give it a little and then stops around 2500 ish.
I still have to make sure it isn't associated with the 123distributor but if it is the alternator, what are my options? Looks like a rebuilt is around 250. Are they reliable?
Root_Werks
post Mar 14 2025, 10:37 AM
Village Idiot
That's a good write up Steve. I remember swapping out an alternator once while still in the 914. Doable for sure, just takes some time.
At least you know what the noise is now.
emerygt350   Squeal... ugh.   Mar 12 2025, 06:27 AM
bdstone914   Got a squeal. It started last year, and I though...   Mar 12 2025, 07:18 AM
emerygt350   Got a squeal. It started last year, and I thoug...   Mar 12 2025, 07:31 AM
moldygreg   Got a squeal. It started last year, and I though...   Mar 12 2025, 09:58 AM
emerygt350   Got a squeal. It started last year, and I thoug...   Mar 12 2025, 10:43 AM
rfinegan   pull the belt and start/drive..no noises= found yo...   Mar 12 2025, 10:46 AM
emerygt350   pull the belt and start/drive..no noises= found y...   Mar 12 2025, 12:50 PM
930cabman   pull the belt and start/drive..no noises= found ...   Mar 12 2025, 01:33 PM
brant   [quote name='emerygt350' post='3196005' date='Mar...   Mar 12 2025, 03:01 PM
rfinegan   [quote name='emerygt350' post='3196005' date='Mar...   Mar 13 2025, 08:05 AM
emerygt350   It's fine for a little bit. Happens all the t...   Mar 12 2025, 02:45 PM
930cabman   It's fine for a little bit. Happens all the ...   Mar 12 2025, 03:22 PM
emerygt350   It's fine for a little bit. Happens all the...   Mar 12 2025, 03:30 PM
ctc911ctc   Just a thought - check to see if the heater fan is...   Mar 12 2025, 03:04 PM
emerygt350   Just a thought - check to see if the heater fan i...   Mar 12 2025, 03:11 PM
emerygt350   Here is the video. Opinions? I still have dreams...   Mar 13 2025, 06:20 AM
930cabman   Here is the video. Opinions? I still have dream...   Mar 13 2025, 06:43 AM
emerygt350   Just swapped out the belt with another I have, no ...   Mar 13 2025, 08:51 AM
930cabman   Just swapped out the belt with another I have, no...   Mar 13 2025, 10:23 AM
emerygt350   bdstone914 has a rebuilder that I am using.   Mar 13 2025, 10:59 AM
anderssj   Went through this about 6 months ago...not the eas...   Mar 13 2025, 11:43 AM
Root_Werks   That's a good write up Steve. I remember swap...   Mar 14 2025, 10:37 AM
emerygt350   Yeah, and now the alternator will be a power adder...   Mar 14 2025, 11:20 AM
jvmarino   I swapped out my original alternator last Fall. I...   Mar 14 2025, 12:55 PM
emerygt350   I swapped out my original alternator last Fall. ...   Mar 14 2025, 03:14 PM
emerygt350   Well, replaced the alternator this morning. Dude....   Mar 22 2025, 12:36 PM
- Lo-Fi Version Time is now: 23rd November 2026 - 11:26 AM
