> A bit more from the brain trust, Still need help with starting at the end of rustoration
worn
post Mar 12 2025, 06:17 PM
Hi folks. Ok, five years and the piles of parts have actually gone back onto the car. And, I er, ah tightened the head nuts to the proper torque. My problem is that it is hard to keep the motor running long enough to tune it. For example timing light.
The problem is that I want to adjust timing and fuel, but The motor isn’t running smooth enough to get there. The motor is a 2056 with the so-called Raby cam from WebCam. The MPS has been messed with, but it ran when parked. Took the motor out to split the case and address oil leaks. One thing led to another and the rust was replaced with yet to rust sheet metal, and paint etc.
I am looking for a starting condition that allows enough running to improve upon. Ideally, I would like the motor to idle somehow. I have a pretty big hint. If before start, with ign on I blip the throttle a few times, the fuel injectors click, and the motor will start, run and die. From this I think that the sparks are there and the injectors are capable of letting out enough gas to fire. The fuel pressure is constant 29 psi, and the injectors have been cleaned and tested. My problem is the MPS and ECU black boxes that govern fueling. I have an AFR gauge, but it would be more useful if the motor ran long enough to get a number to look at.
I am hoping for:
A magic bullet post that says something like clock the seatbelt bolts and it will start,
Or, basic starting adjustments for each thing that can be adjusted or tested. For example, I can static test the timing and measure MPS inductance vs vacuum. What else has to be in line? Head temp resistance value? Throttle TPS switch position or values? You folks comprise so much wisdom, so please let me get the car on the road now that spring is only months away!
emerygt350
post Mar 14 2025, 11:06 AM
Do try running it with the TPS disconnected first.
worn   A bit more from the brain trust   Mar 12 2025, 06:17 PM
emerygt350   You can have an incredibly badly tuned mps and the...   Mar 12 2025, 06:46 PM
worn   You can have an incredibly badly tuned mps and th...   Mar 12 2025, 07:41 PM
Spoke   Can keep it going by throttle. @worn Can you...   Mar 13 2025, 09:29 AM
worn   [quote name='worn' post='3196057' date='Mar 12 20...   Mar 13 2025, 12:55 PM
emerygt350   Sounds like fuel delivery to me. Head temp sensor...   Mar 13 2025, 05:20 AM
VaccaRabite   What is the "So called Raby cam from WebCam...   Mar 13 2025, 05:22 AM
Root_Werks   What is the "So called Raby cam from WebCam...   Mar 13 2025, 02:16 PM
emerygt350   How long can you keep it running, and by running d...   Mar 13 2025, 04:41 PM
worn   How long can you keep it running, and by running ...   Mar 13 2025, 07:19 PM
VaccaRabite   So - again. Your MPS is going to determine your f...   Mar 14 2025, 04:59 AM
worn   So - again. Your MPS is going to determine your ...   Mar 14 2025, 09:15 AM
emerygt350   [quote name='VaccaRabite' post='3196217' date='Ma...   Mar 14 2025, 09:20 AM
emerygt350   I don't know Zach, the mps just isn't that...   Mar 14 2025, 05:11 AM
worn   I don't know Zach, the mps just isn't tha...   Mar 14 2025, 09:29 AM
emerygt350   I don't know Zach, the mps just isn't th...   Mar 14 2025, 09:54 AM
worn   wow, that really does make me wonder about the EC...   Mar 14 2025, 10:37 AM
emerygt350   Do try running it with the TPS disconnected first.   Mar 14 2025, 11:06 AM
worn   Do try running it with the TPS disconnected first...   Mar 14 2025, 03:33 PM
- Lo-Fi Version Time is now: 25th September 2026 - 10:39 AM
