> Squeal... ugh., Alternator bearing?
emerygt350
post Mar 12 2025, 06:27 AM
Got a squeal. It started last year, and I thought "oh, maybe just the belt". Belt is new, tightening it didn't help. Kinda goes away after the engine is hot (haven't been able to test that too much). Alternator works great. Starts to squeal as you give it a little and then stops around 2500 ish.
I still have to make sure it isn't associated with the 123distributor but if it is the alternator, what are my options? Looks like a rebuilt is around 250. Are they reliable?
jvmarino
post Mar 14 2025, 12:55 PM
I swapped out my original alternator last Fall. I was dreading it even though I have a MAXJAX 2 post lift. I took my time and spent about 2 hours taking it out 1 night and another couple of hours putting new one back in the following night. I am sure I could do it quicker now, but this felt like a relaxed pace.
There was a thread on the forum with a step-by-step description, but it seemed much easier because there were no HE's installed or heater ducts. I had to re-familiarize myself with the heating equipment as I had not dug into it since assembling the car 30 years ago, so that added some time in the beginning.
I also struggled with the cooling air elbow. First I didn't realize there was an internal spring wire holding it into the engine fan case, and then when I installed the new elbow I received from 914rubber, it seems to be the wrong size for my year and the boot would not secure to the fan case opening too well. I kept messing with that to get to a point I felt it would stay secured.
It was very helpful to not be on a time line for completion so I could be relaxed about the whole process.
emerygt350
post Mar 14 2025, 03:14 PM
QUOTE(jvmarino @ Mar 14 2025, 12:55 PM) *
Thanks for the information. I have looked at that excellent write up and slapshots video. Gonna take it slow and not rush, it looks like the most frustrating bits are really if you are in a hurry.
emerygt350   Squeal... ugh.   Mar 12 2025, 06:27 AM
bdstone914   Got a squeal. It started last year, and I though...   Mar 12 2025, 07:18 AM
emerygt350   Got a squeal. It started last year, and I thoug...   Mar 12 2025, 07:31 AM
moldygreg   Got a squeal. It started last year, and I though...   Mar 12 2025, 09:58 AM
emerygt350   Got a squeal. It started last year, and I thoug...   Mar 12 2025, 10:43 AM
rfinegan   pull the belt and start/drive..no noises= found yo...   Mar 12 2025, 10:46 AM
emerygt350   pull the belt and start/drive..no noises= found y...   Mar 12 2025, 12:50 PM
930cabman   pull the belt and start/drive..no noises= found ...   Mar 12 2025, 01:33 PM
brant   [quote name='emerygt350' post='3196005' date='Mar...   Mar 12 2025, 03:01 PM
rfinegan   [quote name='emerygt350' post='3196005' date='Mar...   Mar 13 2025, 08:05 AM
emerygt350   It's fine for a little bit. Happens all the t...   Mar 12 2025, 02:45 PM
930cabman   It's fine for a little bit. Happens all the ...   Mar 12 2025, 03:22 PM
emerygt350   It's fine for a little bit. Happens all the...   Mar 12 2025, 03:30 PM
ctc911ctc   Just a thought - check to see if the heater fan is...   Mar 12 2025, 03:04 PM
emerygt350   Just a thought - check to see if the heater fan i...   Mar 12 2025, 03:11 PM
emerygt350   Here is the video. Opinions? I still have dreams...   Mar 13 2025, 06:20 AM
930cabman   Here is the video. Opinions? I still have dream...   Mar 13 2025, 06:43 AM
emerygt350   Just swapped out the belt with another I have, no ...   Mar 13 2025, 08:51 AM
930cabman   Just swapped out the belt with another I have, no...   Mar 13 2025, 10:23 AM
emerygt350   bdstone914 has a rebuilder that I am using.   Mar 13 2025, 10:59 AM
anderssj   Went through this about 6 months ago...not the eas...   Mar 13 2025, 11:43 AM
Root_Werks   That's a good write up Steve. I remember swap...   Mar 14 2025, 10:37 AM
emerygt350   Yeah, and now the alternator will be a power adder...   Mar 14 2025, 11:20 AM
jvmarino   I swapped out my original alternator last Fall. I...   Mar 14 2025, 12:55 PM
emerygt350   I swapped out my original alternator last Fall. ...   Mar 14 2025, 03:14 PM
emerygt350   Well, replaced the alternator this morning. Dude....   Mar 22 2025, 12:36 PM
- Lo-Fi Version Time is now: 23rd November 2026 - 11:26 AM
