> Wheel Spacers on Flared Fenders
HDC
post Mar 14 2025, 08:26 PM
The restoration of my 914-6 is moving along well. The car has steel flared fenders and a set of Fuchs 6x15 will be installed, but I believe I need some spacers to move the wheels outward a bit.
I believe M471 cars used 6x15" wheels and 21mm spacers, am I correct?
I also need longer wheel studs, what is adequate for a 21mm spacer, a 70mm stud?
Thanks
Henry
Attached Image Attached ImageAttached Image
Chris914n6
post Mar 15 2025, 07:23 PM
Jackstands are my life.
I used the 21mm spacers and studs off the rear of an early 944. I think they are 80mm but not sure at this time.
I'd put something wider than 6" on a flared car, or what's the purpose. And if you're not into exact replica I'd do 16" for the shorter sidewall and tire choices. 205/55-16 is stock Boxster fronts and a very common size.
- Lo-Fi Version Time is now: 9th May 2025 - 01:48 PM
