jmargush |
Member ![]() ![]() Group: Members Posts: 484 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
Has anyone experienced the mark on the fan being off from where actual TDC is ?
Last time I had the engine out I put a dowel in cylinder #1 and found TDC and the factory mark was approx. 3/8" tot he left of where I feel TDC on #1 was. I am going to recheck it and see if I made an error the last time I did it. |
mjrrti |
High Desert Member ![]() ![]() Group: Members Posts: 51 Joined: 4-February 14 From: Apple Valley, Ca Member No.: 16,959 Region Association: Southern California ![]() |
Has anyone experienced the mark on the fan being off from where actual TDC is ? Last time I had the engine out I put a dowel in cylinder #1 and found TDC and the factory mark was approx. 3/8" tot he left of where I feel TDC on #1 was. I am going to recheck it and see if I made an error the last time I did it. There should be a groove on the flywheel that you can see in the little opening on the bell housing top and bottom that will get you dead on. I like to get it on TDC and use a center punch to mark the flywheel @ 180 from under the car also. That really helps for valve adjustment. |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,454 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Has anyone experienced the mark on the fan being off from where actual TDC is ? Last time I had the engine out I put a dowel in cylinder #1 and found TDC and the factory mark was approx. 3/8" tot he left of where I feel TDC on #1 was. I am going to recheck it and see if I made an error the last time I did it. There should be a groove on the flywheel that you can see in the little opening on the bell housing top and bottom that will get you dead on. I like to get it on TDC and use a center punch to mark the flywheel @ 180 from under the car also. That really helps for valve adjustment. This, for sure. Set the flywheel at TDC and see where the fan is. |
Lo-Fi Version | Time is now: 20th July 2025 - 01:20 AM |
