PDXBob |
Member ![]() ![]() Group: Members Posts: 60 Joined: 16-May 20 From: Portland Oregon Member No.: 24,272 Region Association: Pacific Northwest ![]() ![]() |
Hi 914’ers,
This is a revival of my old post about the same engine cutting out problem on my 1975 914 (1.8L). It cuts out generally after warmed up and driven for a while. Usually happens under load, like when I’m going up a hill. Doesn’t miss on idle or when I rev it up in the driveway. Based on the work I’ve done so far I’m now thinking must be fuel related. Here’s an (unfortunately) long list of what I’ve checked or replaced: - new Spark Plugs and wires, - new 123Ignition distributor, coil and distributor cap - no vacuum leaks, all ground wires appear in contact and good shape. - ECM wiring appears good and I’ve tried wiggling its wires to see if any faults - Tested the TPS and it’s good, also AFM flap moves smoothly. A couple of other interesting things- I didn’t drive it for about 2 months, and after installing new distributor it ran great for about 2 weeks. Also, on Friday it was cutting out bad, then I stopped at a store for about 1/2 hour and when I restarted and drove home the cut out had disappeared. So, I’m now think fuel system related. Any ideas would be greatly appreciated! PDXBob |
Artfrombama |
Member ![]() ![]() Group: Members Posts: 280 Joined: 21-January 24 From: Alabama Member No.: 27,870 Region Association: South East States ![]() ![]() |
Missing under a load is usually point gap too narrow (electronic, not this) or fuel starvation. Fuel filter, pinched fuel line or low fuel pressure
Lo-Fi Version | Time is now: 11th May 2025 - 11:40 AM |
