| SVG223 |
Mar 13 2025, 08:35 PM
Member ![]() ![]() Group: Members Posts: 115 Joined: 6-February 22 From: Benton Arkansas Member No.: 26,317 Region Association: None |
2400-2600 rpm stumble with partial throttle, stumble goes away under full throttle. Runs smooth at all other RPMs. Pulled the plugs, a little lean maybe?
Edit 3-17-25 I found a possible cause; worn distributor bushings causing a variation in the points gap. |
| emerygt350 |
Mar 18 2025, 05:24 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,680 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Yeah, a hole there will just be a vacuum leak at idle. But makes a new dizzy more of a thing I guess. Sounds like yours is due for a complete overhaul.
SVG223 2500 RPM stumble partial throttle 2.0 -4 Mar 13 2025, 08:35 PM
jim_hoyland TPS ? Common issue…. Mar 13 2025, 08:40 PM
dr914@autoatlanta.com as a stab in the dark, I agree, and check the grou... Mar 15 2025, 11:02 AM
gonzo54 2.0 DJET? I would suspect TPS board - there are ma... Mar 13 2025, 08:49 PM
SVG223 That sounds reasonable. I replaced the TPS board 3... Mar 13 2025, 09:03 PM
emerygt350 That is looking very lean as well. Is this stock?... Mar 14 2025, 06:40 AM
SVG223
That is looking very lean as well. Is this stock... Mar 14 2025, 05:23 PM
Superhawk996
I had these plugs under a strong LED shop light ... Mar 15 2025, 07:07 AM
SVG223
I had these plugs under a strong LED shop light... Mar 15 2025, 01:26 PM
Superhawk996 None at of those plugs are lean Mar 14 2025, 08:05 AM
emerygt350
Maybe I don... Mar 14 2025, 10:00 AM
Superhawk996
Maybe I don... Mar 14 2025, 11:46 AM
emerygt350
[quote name='emerygt350' post='3196271' date='Mar... Mar 14 2025, 12:02 PM
windforfun Try some electronic contact cleaner on the TPS. T... Mar 14 2025, 11:44 AM
SVG223
Try some electronic contact cleaner on the TPS. ... Mar 14 2025, 07:44 PM
Superhawk996 Here’s your post ?
http://www.914world.com/bbs2/... Mar 14 2025, 12:31 PM
emerygt350 To me that is a clean plug with your 'powder... Mar 14 2025, 03:26 PM
emerygt350 I chased what I thought was a lean miss for months... Mar 15 2025, 06:04 AM
SVG223
I chased what I thought was a lean miss for month... Mar 15 2025, 02:53 PM
brant Agree with Superhawk.
All of the basics first
T... Mar 15 2025, 10:06 AM
SVG223
... Mar 15 2025, 01:35 PM
ctc911ctc Strongly suggest that you buy this book, has saved... Mar 15 2025, 11:54 AM
SVG223 Well, I tried the suggestion from @emerygt350 ab... Mar 15 2025, 03:35 PM
emerygt350 Interesting. I would also check the coil too. Al... Mar 15 2025, 04:04 PM
brant Doubt it is the distributor points for fuel inject... Mar 15 2025, 05:06 PM
emerygt350 I had another thought as well... Does your car hav... Mar 16 2025, 05:32 AM
SVG223
I had another thought as well... Does your car ha... Mar 16 2025, 02:03 PM
JeffBowlsby A better price on the Tech Tips book - Direct from... Mar 16 2025, 08:13 AM
SVG223
A better price on the Tech Tips book - Direct fro... Mar 16 2025, 02:05 PM
emerygt350 The car will run fine without the TPS. It's o... Mar 16 2025, 03:55 PM
SVG223
The car will run fine without the TPS. It's ... Mar 16 2025, 04:23 PM
emerygt350 Excellent. Often that gets put on something...
W... Mar 16 2025, 06:23 PM
SVG223 I found some play in the distributor shaft. I thou... Mar 16 2025, 09:40 PM
emerygt350 Don't forget your dwell. That can make a big ... Mar 17 2025, 05:27 AM
SVG223
Don't forget your dwell. That can make a big... Mar 17 2025, 02:04 PM
SVG223 Now I'm thinking about buying a dwell meter an... Mar 17 2025, 01:51 PM
emerygt350 Bad bearings can do that. If I were you I would j... Mar 17 2025, 02:56 PM
FlacaProductions The petronix issue with leaving your ignition on w... Mar 17 2025, 07:25 PM
SVG223
The petronix issue with leaving your ignition on ... Mar 17 2025, 07:28 PM
SVG223 The vacuum retard diaphragm has a hole in it. That... Mar 17 2025, 07:27 PM
SVG223
Yeah, a hole there will just be a vacuum leak at ... Mar 18 2025, 02:47 PM
emerygt350 No, I have the non Bluetooth version and it has be... Mar 19 2025, 08:26 AM
SVG223 I cleaned the distributor; the mechanical advance ... Mar 19 2025, 02:53 PM
emerygt350 I would check your plugs and watch your head tempe... Mar 19 2025, 04:45 PM
emerygt350 Oh, and did you get a dwell meter? Incorrect dwel... Mar 19 2025, 04:58 PM
SVG223 duplicate Mar 19 2025, 06:15 PM
SVG223 No dwell meter. I don't think this worn distri... Mar 19 2025, 06:15 PM
ctc911ctc
No dwell meter. I don't think this worn distr... Mar 20 2025, 03:21 PM
emerygt350 A poor spark can result in a miss. And don't ... Mar 20 2025, 05:30 AM
emerygt350
I wouldn't ignore the dwell. Could be a re... Mar 20 2025, 06:37 AM
ctc911ctc My 914 mentor, Richard Towle would say that for th... Mar 20 2025, 03:13 PM
emerygt350 duplicate post Mar 20 2025, 06:37 AM
SVG223
duplicate post
I ordered a Hot-Spark electronic ... Mar 20 2025, 02:39 PM
brant a worn out distributor shaft will make a newer poi... Mar 20 2025, 03:26 PM
brant I have a half dozen DJet distributors from differe... Mar 20 2025, 03:28 PM
SVG223 It looks like I have about .005" of lateral p... Mar 20 2025, 04:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th July 2026 - 03:56 AM |
