Al Meredith |
Senior Member ![]() ![]() ![]() Group: Members Posts: 973 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 ![]() |
I just finished rebuilding a 912 4 speed transmission # 902/0 with the proper gears A,H,Q,X . This is an early aluminum case and I believe it can be converted to a 914 side shifter. I have heard that the 4 speed was preferred for high torque ( V8) conversion because of the now first gear is not hung out to the rear of the mid plate bearing where it has no support.
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,316 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Also, when you convert a 914 to a 4 speed for use with a V-8, you get a taller 1st gear. The 901 factory 4 speed has an A first gear. If you convert a 5 speed, you get a F first gear. The V-8 likes the taller first gear.
Lo-Fi Version | Time is now: 9th May 2025 - 06:18 PM |
