> 914World Classifieds Rules
> 912 4 speed trans $1500, covert to 914
Al Meredith
post Mar 17 2025, 12:34 PM
I just finished rebuilding a 912 4 speed transmission # 902/0 with the proper gears A,H,Q,X . This is an early aluminum case and I believe it can be converted to a 914 side shifter. I have heard that the 4 speed was preferred for high torque ( V8) conversion because of the now first gear is not hung out to the rear of the mid plate bearing where it has no support. Attached Image Attached ImageAttached ImageAttached Image
Jack Standz
post Mar 18 2025, 06:34 PM
A stock 912 transmission will give you four speeds in reverse and one forward.
Unless you run it upside down or put the ring gear on the other side, is that even possible or recommended?
- Lo-Fi Version Time is now: 9th May 2025 - 06:05 PM
