| frank_c |
Mar 18 2025, 10:56 PM
Member ![]() ![]() Group: Members Posts: 108 Joined: 29-December 24 From: Austin, TX Member No.: 28,542 Region Association: None |
Hello,
I acquired a '76 914 2.0 a little over a month ago. The car had the original '76 exhaust system on it, and as part of many repairs & changes I have made so far, I swapped out the original exhaust with a set of new SSI heat exchangers and a MittelMotor muffler. Note that the original exhaust had what I suspected was a small exhaust leak as the engine would backfire a few seconds after every shutdown. After the exhaust swap (with new copper gaskets), I took the car for a quick test run and it backfired excessively. At first, I thought maybe one of the gaskets became dislodged when I was fitting the HEs, but when I pulled the HEs all the gaskets were in place. Upon further inspection, the leak appears to be coming from cylinder 3. Photo 1 shows Cyl 3 before I removed the copper gasket with signs of the gasket not sealing at the bottom of the port. Photo 1: I confirmed that the new SSI HE tubes were flat and parallel where they mated to the head (photo 2). Photo 2: I removed all the gaskets and cleaned the gasket mating surface of all the ports to inspect the heads for damage. Photo 3 shows the Cyl 3 port. It's not easy to see in the photo, but there is a slight indentation in the bottom of the mating surface that corresponds to where the black mark is on the head from the leak. Photo 4 shows the indentation a little better. Photo 3: Photo 4: On Cyl 4, I noticed that the port has a strange step in the mating surface at the top of photo 5, but it appears to be sealing ok. Photo 5: The ports on Cyl 1 & 2 look good. So here's my question - do you think that if I were to anneal the gaskets, and use high-temp copper RTV, that I can get Cylinders 3 & 4 to seal given the non-perfect mating surface on the head? Or does the cyl 3/4 head need to be repaired? Note that I did not anneal the gaskets previously, and only used some grease to hold them in place when fitting the HEs. Thanks for any advice, Frank |
| TheCabinetmaker |
Mar 19 2025, 10:20 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Did you anneal the copper gaskets?
frank_c Will These Exhaust Ports Seal? Mar 18 2025, 10:56 PM
73-914
Hello,
I acquired a '76 914 2.0 a little over... Mar 19 2025, 05:48 PM
frank_c Ok, thanks for confirming that the annealing proce... Mar 19 2025, 09:07 PM
Montreal914 High temp RTV??? :blink: Mar 19 2025, 11:28 PM
bkrantz
Be gone, satan! Mar 22 2025, 07:42 PM
Superhawk996
Be gone, satan!
... Mar 22 2025, 09:00 PM
barefoot I think you'll have sealing problems with the ... Mar 22 2025, 01:25 PM
rhodyguy Tighten the nuts in an X pattern and in stages inc... Mar 23 2025, 12:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd October 2026 - 05:12 AM |
