Literati914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,020 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
1.7 that was supposedly rebuilt just before I purchased the project approx 7 year ago. Never started before. D-jet. Electronic unit replacing the orig. points. Engine currently installed in the engine bay. I primed the oil system the other day and now the idiot light will go out after a couple seconds of cranking.
About the 3rd time or so of trying to start the engine.. it seemed to have lit, it only lasted about 2 seconds (IMG:style_emoticons/default/biggrin.gif) but it felt good, like it wouldn’t take long. Unfortunately it’s not done much but turn over strong since then. Sometimes it’ll do a little shuffle like it’s gonna start, but no. I checked the plugs and they have spark, they seemed slightly damp at the electrodes, I also pulled the little small extra bolt on the fuel rail at the driver’s side to see if fuel was making it to the injectors and yes it is apparently. This 1.7 has a fan with 2 markings… a “0” and an “|” …. Haynes says it’s supposed to have 3 markings but mine does not. If I insert a screwdriver into #1 cylinder and manually bring the fan around via a wrench on the alternator bolt (pulling it towards me from the driver’s side).. I come to the “|” first, before the piston is completely at the top. So I’m speculating that “|” is 5degrees btdc . And this is the mark I’m using to set my distributor. Does that sound right? Attached thumbnail(s) ![]() |
Literati914 |
Quick update - after testing pressure at the pump and getting 50+ psi.. I moved back to the rear, under the car and tested just after the filter.. 50psi…I’d already checked at the T where I eliminated the CSV..I never got pressure there (but I bet the CSV is still good and will probably go back into the system).
So I pulled the short metal fuel lines on the passenger’s sidewall and found them both completely clogged up. I could have sworn I checked them before installation but I guess maybe not. I have some replacements on the way. Will report back in a couple days. Fingers crossed theses will give me back my missing fuel pressure. |
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,034 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
Quick update - after testing pressure at the pump and getting 50+ psi.. I moved back to the rear, under the car and tested just after the filter.. 50psi…I’d already checked at the T where I eliminated the CSV..I never got pressure there (but I bet the CSV is still good and will probably go back into the system). So I pulled the short metal fuel lines on the passenger’s sidewall and found them both completely clogged up. I could have sworn I checked them before installation but I guess maybe not. I have some replacements on the way. Will report back in a couple days. Fingers crossed theses will give me back my missing fuel pressure. Holy cow, varnish, trash? Wow, that is a new one for me. Fingers crossed that fixes it all! |
Lo-Fi Version | Time is now: 15th July 2025 - 01:39 PM |
