> Will These Exhaust Ports Seal?
frank_c
post Mar 18 2025, 10:56 PM
Hello,
I acquired a '76 914 2.0 a little over a month ago. The car had the original '76 exhaust system on it, and as part of many repairs & changes I have made so far, I swapped out the original exhaust with a set of new SSI heat exchangers and a MittelMotor muffler. Note that the original exhaust had what I suspected was a small exhaust leak as the engine would backfire a few seconds after every shutdown.
After the exhaust swap (with new copper gaskets), I took the car for a quick test run and it backfired excessively. At first, I thought maybe one of the gaskets became dislodged when I was fitting the HEs, but when I pulled the HEs all the gaskets were in place. Upon further inspection, the leak appears to be coming from cylinder 3. Photo 1 shows Cyl 3 before I removed the copper gasket with signs of the gasket not sealing at the bottom of the port.
Photo 1:
I confirmed that the new SSI HE tubes were flat and parallel where they mated to the head (photo 2).
Photo 2:
I removed all the gaskets and cleaned the gasket mating surface of all the ports to inspect the heads for damage.
Photo 3 shows the Cyl 3 port. It's not easy to see in the photo, but there is a slight indentation in the bottom of the mating surface that corresponds to where the black mark is on the head from the leak. Photo 4 shows the indentation a little better.
Photo 3:
Photo 4:
On Cyl 4, I noticed that the port has a strange step in the mating surface at the top of photo 5, but it appears to be sealing ok.
Photo 5:
The ports on Cyl 1 & 2 look good.
So here's my question - do you think that if I were to anneal the gaskets, and use high-temp copper RTV, that I can get Cylinders 3 & 4 to seal given the non-perfect mating surface on the head? Or does the cyl 3/4 head need to be repaired? Note that I did not anneal the gaskets previously, and only used some grease to hold them in place when fitting the HEs.
Thanks for any advice,
Frank
Montreal914
post Mar 19 2025, 11:28 PM
High temp RTV??? (IMG:style_emoticons/default/blink.gif)
bkrantz
post Mar 22 2025, 07:42 PM
QUOTE(Montreal914 @ Mar 19 2025, 10:28 PM) *
Be gone, satan!
- Lo-Fi Version Time is now: 2nd October 2026 - 05:13 AM
