| IronHillRestorations |
Apr 3 2025, 04:05 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,926 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
I did a ground up build on a really nice chassis about 22 years ago. It changed hands twice ending up with jerhofer, who took it up several notches. It’ll be fun to watch and see what it hammers at.
Blue wide body 914 6 conversion Attached thumbnail(s) |
| echocanyons |
Apr 3 2025, 09:53 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,115 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California
Thanks for the info Ken!
Turbo Kraft also previously sold a drive by wire pedal. https://parts.turbokraft.com/collections/91...=32214124265530 The connection can attach to a Jenvey actuator or probably any similar standard type. It would be nice to have this over the cable driven version. Definitely requires an engine management system though. Anyone else go this route or have thoughts on a solution? |
| ClayPerrine |
Apr 4 2025, 06:09 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Thanks for the info Ken! Turbo Kraft also previously sold a drive by wire pedal. https://parts.turbokraft.com/collections/91...=32214124265530 The connection can attach to a Jenvey actuator or probably any similar standard type. It would be nice to have this over the cable driven version. Definitely requires an engine management system though. Anyone else go this route or have thoughts on a solution? I am going with drive by wire for the flat fan conversion. I am going to use a Nissan 350Z throttle pedal sensor. It will all be tied back into the MS3Pro for the ability to run traction control. So I can actually have a hope of driving it in the rain without roasting the tires. But I am definitely adding a button to turn off the traction control in the dry. I will take the roller off the arm, and add a Porsche ball stud. I will make a hole in the top of the tunnel behind the pedal box, and mount it there. I will use a rod to hook it to the stock throttle linkage. I will also add a throttle return spring between the pedal bellcrank and the chassis until I get the correct feel from the gas pedal. Then I will add one of these to run it... (IMG:http://www.914world.com/bbs2/uploads_offsite/shop.fullest.fi-1143-1743768550.1.png) And at the engine end, I am using a pair of BMW M3 throttle actuators, one for each cylinder bank. ![]() |
IronHillRestorations Now on BAT one of my old builds Apr 3 2025, 04:05 PM
jhynesrockmtn
I did a ground up build on a really nice chassis ... Apr 3 2025, 07:51 PM
echocanyons I am very interested in the drive by wire.
What fo... Apr 3 2025, 08:05 PM
saladin
What f... Apr 3 2025, 09:43 PM
sixnotfour :trophy: :popcorn: Apr 3 2025, 08:42 PM
Ron914
[quote name='echocanyons' post='3199616' date='Ap... Apr 4 2025, 09:54 AM
ClayPerrine
[quote name='echocanyons' post='3199616' date='A... Apr 4 2025, 02:16 PM
Ron914
[quote name='Ron914' post='3199669' date='Apr 4 2... Apr 4 2025, 09:03 PM
Ron914 I too received a notification for this car , I add... Apr 3 2025, 10:26 PM
Ron914 Here you go Clay, @ClayPerrine . Looking forward ... Apr 4 2025, 10:10 PM
Ron914 Here you go Clay, @ClayPerrine . Looking forward ... Apr 4 2025, 10:14 PM
ClayPerrine Yea.. that's great. It won't happen this y... Apr 5 2025, 04:55 AM
Ron914
Yea.. that's great. It won't happen this ... Apr 5 2025, 06:15 AM
Dave_Darling Here's a thread that Jer posted on Pelican fol... Apr 6 2025, 12:33 AM
Ron914
Here's a thread that Jer posted on Pelican fo... Apr 8 2025, 10:02 AM
Ron914
[quote name='Dave_Darling' post='3199867' date='A... Apr 8 2025, 10:04 AM
Ron914 My bad , I figured it out . Apr 8 2025, 10:39 AM
Dave_Darling Weird. I wonder if I replied in the wrong window,... Apr 9 2025, 06:03 AM
Ron914
Weird. I wonder if I replied in the wrong window... Apr 9 2025, 06:44 AM
gereed75 I saw Jer’s build thread in the past but this Ba... Apr 10 2025, 09:02 AM
sb914 Sold $95,914 Wow ! Apr 10 2025, 12:50 PM
Root_Werks I think the buyer will be a very happy 914 owner... Apr 10 2025, 01:16 PM
gereed75 This car exemplifies the lure of the resto mod gen... Apr 10 2025, 02:54 PM
Steve Impressive car. It would be nice if someone could... Apr 11 2025, 08:10 AM
Justinp71
Impressive car. It would be nice if someone coul... Apr 11 2025, 09:21 AM
Steve
Indeed a very impressive car. @[url=http://www.... Apr 11 2025, 09:59 AM
IronHillRestorations Closed at $95,914 Apr 12 2025, 07:04 PM
sharper
Closed at $95,914
Wow! This makes me c... Apr 20 2025, 09:31 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:45 AM |
