> Eric's Six Conversion, chassis work has finally commenced.
Detroit
post Mar 22 2021, 08:20 PM
Greetings all...
As the title suggests, I'm undertaking a six cylinder heart transplant on my four cylinder '74 914. I've always wanted to build a hot rod of some sort, and a 3.X 914 seems a pretty solid choice. I just hope the patient and donor organ both survive the surgery...
The motor is a 3.0L out of an '82 SC. It needs rebuilding. I'm going to start a separate thread for that over on the Pelican forum in the engine rebuilding section, because I'm going to need lot's of advice. I realize that there are plenty of peops here who've built sixes, but as that forum is dedicated purely to the task it makes sense to me to start the thread there. I'll paste a link for anyone interested once I've got it started. It's not going to be some crazy race motor. I just want a good reliable street engine. I'm not a hundred percent sure what I'm going to do with the chassis at this point, but I have plenty of time to think about it. I work slow.
The overall plan is to rebuild the motor, and then get it running on a start cart, which I've already started to cobble up. At that point I'll pull the four cylinder, do any chassis mods, and stick in the new engine. It all sounds so simple when I type it... Stupid brain.
I've already torn the engine down to the long block, but have paused to get a few things around the garage cleared up. There will be additional pauses along the way. I've got a zillion things to do around here... I'm pretty determined to get this done though, so hopefully said pauses will be brief.
I will do my best to keep everyone updated along the way. And of course supply plenty of pictures. Here's a few to start.
EDIT - Here's a link to the engine build thread:
https://forums.pelicanparts.com/911-engine-...3-0l-build.html
The car.
The six.
The start cart (and mock up engine and trans).
Detroit
post Apr 7 2025, 10:00 AM
It continues to be a challenge to find significant blocks of time for this project. As I'm sure most peops who attempt these undertakings will understand. But, I do make an effort to make some small amount of headway at least every few days. A little progress is better than none...
I've had a finished carpenter installing moldings throughout the house, and I gave him the 'parking side' (as opposed to the 'shop side') of the garage in which to set up all of his equipment. So, for over a month the 914 has been up on the hoist with the Ferrari under it.
I did, however, have access to my bench and sand blast cabinet, so I took to refurbishing some of the suspension bits.
I welded sway bar drop link tabs to the control arms, and dropped them off at the powder coater...
...media blasted and painted the struts. Jamie has installed new bushings for me. These are Bilstein struts which of course were originally green. As this is a restomod rather than a restoration, I figured I'd change to yellow so they'll match the shocks.
The rear hubs I had plated some time ago. This weekend I Alodined the front hubs in the hope it's provide some small amount of corrosion protection. I suspect it won't do much, but I already had the chems to do carburetor bodies... Then I pressed all the studs back in.
Detroit   Eric's Six Conversion   Mar 22 2021, 08:20 PM
914Sixer   Way cool. Engine cart is a excellent start. Grea...   Mar 22 2021, 08:26 PM
Superhawk996   Can’t wait to see this come together :headbange...   Mar 22 2021, 08:44 PM
Root_Werks   Look how nice that looks! My 914-6 conversion...   Mar 22 2021, 09:15 PM
mb911   Looks great.. a better start then mine was   Mar 23 2021, 05:27 AM
Detroit   Thank, fellas. And, Phil, consider this start cart...   Mar 23 2021, 05:40 AM
Detroit   Ben, that's your muffler hanging off the back ...   Mar 23 2021, 05:47 AM
mb911   Ben, that's your muffler hanging off the back...   Mar 23 2021, 07:39 AM
Detroit   Absolutely they will fit. You may have to enlarge...   Mar 23 2021, 07:51 AM
mepstein   Absolutely they will fit. You may have to enlarg...   Mar 23 2021, 08:31 AM
CptTripps   Looks like you're off to a great start. Can...   Mar 23 2021, 05:50 AM
Dion   What a fantastic combo. Good luck. You look to hav...   Mar 23 2021, 06:21 AM
Mark Henry   Good start. :thumbsup: You might like to look at ...   Mar 23 2021, 06:22 AM
gereed75   Not Ben, but I will chime in with my experience- t...   Mar 23 2021, 06:53 AM
Cairo94507   Excellent project and a great starting point. You...   Mar 23 2021, 07:48 AM
roblav1   On heat exchangers, it's easier if you can att...   Mar 23 2021, 03:12 PM
Detroit   Thanks for all the input. I'm not at all worr...   Mar 24 2021, 07:12 AM
Mark Henry   Thanks for all the input. I'm not at all wor...   Mar 24 2021, 07:35 AM
Detroit   I haven't gotten anything else done on the sta...   Mar 30 2021, 05:06 PM
Detroit   Well, it's about time I drag this thread out o...   Nov 22 2024, 11:47 AM
Detroit   The car has also undergone a bit of lightening... ...   Nov 22 2024, 11:52 AM
Montreal914   Good looking tub! :) I will be watching and ...   Nov 22 2024, 12:16 PM
930cabman   :popcorn: going to be a great project   Nov 22 2024, 03:44 PM
rjames   Agree with Montreal914 that the original sway bars...   Nov 22 2024, 04:23 PM
Detroit   Thanks for the input, fellas. I will do my best t...   Nov 25 2024, 07:54 AM
rick 918-S   That's a lot of Dirt! :blink: Nice projec...   Nov 26 2024, 06:39 AM
Detroit   I just love picking stuff up from the plater!....   Nov 27 2024, 11:20 AM
Detroit   Okay, I could use a bit of help, please... I'v...   Dec 2 2024, 01:27 PM
davep   If you have removed the clip in the groove at the ...   Dec 2 2024, 02:08 PM
Detroit   Never mind, thanks. I just found the tech article...   Dec 2 2024, 02:22 PM
Detroit   @[url=http://www.914world.com/bbs2/index.php?showu...   Feb 11 2025, 11:40 AM
technicalninja   Did you rebuild the rear proportioning valve yours...   Feb 11 2025, 02:14 PM
worn   Did you rebuild the rear proportioning valve your...   Feb 11 2025, 08:40 PM
Graydingo   Nice work so far. The 3.0 is going to be fun.   Feb 11 2025, 09:41 PM
Detroit   Thanks for the compliments, fellas. @techniclaninj...   Feb 12 2025, 06:04 AM
technicalninja   Thanks for the compliments, fellas. @techniclanin...   Feb 12 2025, 11:37 AM
burton73   @detroit Hi I just sent you a PM Best Bob :w...   Feb 12 2025, 12:23 PM
Detroit   TNinja, thanks for the info. Good call on those P...   Feb 24 2025, 08:53 AM
Detroit   I found some time this weekend, after a week in Fl...   Feb 24 2025, 09:01 AM
Cairo94507   Works of art. :beer2:   Feb 24 2025, 09:31 AM
Detroit   Just adding my Bilstein question thread, so that I...   Feb 24 2025, 12:22 PM
Detroit   Well, I finally got all the required bits to put t...   Mar 13 2025, 05:49 AM
Superhawk996   :drooley:   Mar 13 2025, 08:10 AM
Detroit   It continues to be a challenge to find significant...   Apr 7 2025, 10:00 AM
- Lo-Fi Version Time is now: 22nd November 2026 - 11:23 PM
