| seanpaulmc |
Apr 12 2025, 01:36 PM
Member ![]() ![]() Group: Members Posts: 458 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States
‘73 car
How does this rear tow hook bracket assembly come apart? The threaded tube is welded to the support bracket. The support bracket is welded to the tail panel. The threaded tube extends thru the tail panel into another bracket on the inside of the tail panel. Are they attached? How are they attached? Is the tube part of the inside bracket, or is it part of the outside bracket? Thank you, Sean |
| rgalla9146 |
Apr 12 2025, 07:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,984 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
It looks like you're on the right path on the outside bracket. Finish drilling out the spots then grind off the welds that attach the tube with a grinding disc. That grinding will probably have to be done from the bottom and the top. On the top it will be through the bracket itself but that can be a benefit when re-attaching. I imagine you're doing this for a proper restoration ? I'd do the same myself. |
seanpaulmc Rear Tow Hook Support Bracket removal Apr 12 2025, 01:36 PM
bdstone914
‘73 car
How does this rear tow hook bracket as... Apr 12 2025, 05:05 PM
bdstone914 If you are replacing the tail panel you probably n... Apr 12 2025, 05:22 PM
914werke :agree: its 2 pieces, & the tube is part of t... Apr 12 2025, 05:42 PM
bkrantz FWIW I deleted the bracket when I rebuilt and rein... Apr 12 2025, 07:03 PM
seanpaulmc Your feedback is very helpful, All. Those picture... Apr 13 2025, 06:28 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st August 2026 - 12:51 AM |
