> Installing CSP carb linkage
burlybryan
post Apr 14 2025, 06:59 PM
I have a hex bar linkage and I want to install a CSP linkage. Do you think I can reuse my existing throttle cable bracket and cable? The orientation/angle appears like it should work, but wanted to check because I figure someone else has done this before.
Thanks!
Bryan
porschetub
post Apr 14 2025, 10:03 PM
QUOTE(burlybryan @ Apr 15 2025, 01:59 PM) *
Thanks!
Bryan
Think you will be fine ? if not you could modify the one you have if the cable is too long ,
I used one on my last build but it was a generic Chinese copy ,replaced the crappy loose joints with CB Performance ones ,never found twin carbs SO easy to setup on a T4 .
Cheers.
- Lo-Fi Version Time is now: 17th November 2025 - 08:33 PM
