> Whats wrong with our ignition switches?, What do we know?
JeffBowlsby
post Apr 16 2025, 03:29 PM
"Ignition switches are junk"
Regularly hear this and similar consternation.
I have continuously owned one or more 914s since 1998...think I have replaced only 1 ignition switches over that time, in one car. My current primary car I have had for over twenty years, still on the original switch as far as I know, I have not replaced it during my ownership.
None my cars have ever had the added relay although I'm not against it.
For those switches removed and in other key ignition switches I have opened up, what I see is part of the housing is cracked in similar locations. Maybe from years of torquing the key over? Not sure. I don't see melted housings (believe they are nylon), no smoke residue or anything out of line, just the cracked housing. Suspect the cracked housing causes some internal misalignment of the internal contacts...i.e. the switch goes bad and needs replacement.
I am thinking the problem is the switch housings that break, not anything to do with excessive current flow through the switch.
Educate me please.
bkrantz
post Apr 16 2025, 07:39 PM
My car came with a relay added to the starter, a push button added under the dash, and a cracked ignition switch. During my rebuild, I removed all the extras, replaced the switch, and renewed some of the wiring. I have no problems with making the starter motor spin.
JeffBowlsby   Whats wrong with our ignition switches?   Apr 16 2025, 03:29 PM
wonkipop   "Ignition switches are junk" Regularly...   Apr 16 2025, 03:51 PM
Root_Werks   Similar here, replaced only one in a 914 over 35+ ...   Apr 16 2025, 04:05 PM
wonkipop   @JeffBowlsby just asked mike#1. 911 switches pro...   Apr 16 2025, 04:25 PM
JeffBowlsby   Without excessive current, then why the regular pr...   Apr 16 2025, 04:37 PM
Superhawk996   Without excessive current, then why the regular p...   Apr 16 2025, 04:56 PM
ctc911ctc   Just thinking outloud.... there is no current limi...   Apr 16 2025, 05:14 PM
Superhawk996   Not sure what the impulse current is on the Solin...   Apr 16 2025, 08:13 PM
bdstone914   [quote name='ctc911ctc' post='3201402' date='Apr ...   Apr 17 2025, 04:26 AM
Superhawk996   If it draws 25 amps you don't tonk it needs...   Apr 17 2025, 07:14 AM
GregAmy   On the first point - I don’t think it’s fair ...   Apr 17 2025, 07:27 AM
ctc911ctc   I only have my personal experience 1970 1.7 - in...   Apr 16 2025, 05:05 PM
bkrantz   My car came with a relay added to the starter, a p...   Apr 16 2025, 07:39 PM
Jgilliam914   My car came with a relay added to the starter, a ...   Apr 17 2025, 03:28 PM
Dlee6205   Replacing ignition switches has become standard pr...   Apr 16 2025, 07:50 PM
Superhawk996   Well know fact . . . When it doesn’t start if yo...   Apr 16 2025, 08:08 PM
davep   It was about 1975 that I purchased a used 73 914. ...   Apr 16 2025, 08:22 PM
Justinp71   I added a relay because even after a new switch, o...   Apr 16 2025, 09:40 PM
Superhawk996   Greg - You’re right about the roadside “relay...   Apr 17 2025, 07:36 AM
GregAmy   Far too often it is used to Band-Aid underlying is...   Apr 17 2025, 08:34 AM
Dave97   I have another problem I’ve been chasing. 1975 ...   Apr 17 2025, 08:26 AM
Superhawk996   I have another problem I’ve been chasing. 1975...   Apr 17 2025, 09:18 AM
TheCabinetmaker   I have another problem I’ve been chasing. 1975...   Oct 3 2025, 04:37 AM
JeffBowlsby   I have not had the electrical portion of the switc...   Apr 17 2025, 09:24 AM
Dave97   I tried jb weld, let it dry and then put it togeth...   Apr 17 2025, 09:31 AM
Superhawk996   I tried jb weld, let it dry and then put it toget...   Apr 17 2025, 10:05 AM
Ishley   I’ m on my 3rd switch in 2 yrs. The first one th...   Apr 17 2025, 08:51 PM
orthobiz   When I bought my 1974 1.8 in 2007, the ignition sw...   Apr 18 2025, 06:55 AM
ConeDodger   "Ignition switches are junk" Regularly...   Apr 18 2025, 07:46 AM
chmillman   Mine went out yesterday... There are a bunch of r...   Sep 30 2025, 08:52 AM
Ishley   I've had several go out in 2 years... The iss...   Sep 30 2025, 10:32 AM
tomeric914   I spoke to George at Auto Atlanta to complain abo...   Oct 11 2025, 06:39 AM
Olympic 914   About 10 years ago, my switch failed. I was...   Oct 11 2025, 07:03 AM
Superhawk996   For those that have melted switches, one thing th...   Oct 11 2025, 07:27 AM
tomeric914   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Oct 11 2025, 06:20 PM
Superhawk996   [b]@[url=http://www.914world.com/bbs2/index.php?...   Oct 12 2025, 11:31 AM
chmillman   Local Porsche dealer just called and said my repla...   Oct 2 2025, 04:52 AM
JeffBowlsby   Avoid cutting any wires. Just remove the 50 wire ...   Oct 2 2025, 09:02 AM
chmillman   Thanks @JeffBowlsby , will do... Here is the par...   Oct 2 2025, 11:31 AM
trojanhorsepower   I'll add my experience. Hugh and I tried to s...   Oct 2 2025, 05:41 PM
DRPHIL914   my 2cents worth and experience with my 15 years of...   Oct 8 2025, 12:45 PM
chmillman   So got the Partworks switch in a couple of days ag...   Oct 9 2025, 02:50 AM
DRPHIL914   So got the Partworks switch in a couple of days a...   Oct 9 2025, 06:10 AM
chmillman   so one difference that I see is that the top pic...   Oct 9 2025, 08:20 AM
DRPHIL914   [quote name='DRPHIL914' post='3227384' date='Oct ...   Oct 10 2025, 11:03 AM
chmillman   So, following the excellent Pelican Parts instruct...   Oct 11 2025, 02:41 AM
chmillman   So, since I had everything mostly apart anyway, ju...   Oct 11 2025, 11:33 AM
Superhawk996   Wondering if I shouldn’t wire a relay from batt...   Oct 11 2025, 12:10 PM
chmillman   Your problem and symptoms are indicating you hav...   Oct 11 2025, 03:12 PM
Dave_Darling   Your car is a 74, I see. I didn't read throug...   Oct 11 2025, 03:43 PM
Superhawk996   Your car is a 74, I see. I didn't read throu...   Oct 12 2025, 11:32 AM
chmillman   IT'S FIXED... OK, you guys are going to have ...   Oct 12 2025, 11:35 AM
Superhawk996   Glad you’re back :driving: :Qarl:   Oct 12 2025, 12:12 PM
StarBear   Lesson learned and noted. Thanks!!   Oct 12 2025, 02:23 PM
JamesJ   So has it been determined that the $50 Porsch...   Oct 20 2025, 07:39 PM
- Lo-Fi Version Time is now: 28th April 2026 - 04:30 PM
