| JeffBowlsby |
Apr 16 2025, 03:29 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,245 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
"Ignition switches are junk"
Regularly hear this and similar consternation. I have continuously owned one or more 914s since 1998...think I have replaced only 1 ignition switches over that time, in one car. My current primary car I have had for over twenty years, still on the original switch as far as I know, I have not replaced it during my ownership. None my cars have ever had the added relay although I'm not against it. For those switches removed and in other key ignition switches I have opened up, what I see is part of the housing is cracked in similar locations. Maybe from years of torquing the key over? Not sure. I don't see melted housings (believe they are nylon), no smoke residue or anything out of line, just the cracked housing. Suspect the cracked housing causes some internal misalignment of the internal contacts...i.e. the switch goes bad and needs replacement. I am thinking the problem is the switch housings that break, not anything to do with excessive current flow through the switch. Educate me please. |
| JeffBowlsby |
Apr 16 2025, 04:37 PM
Without excessive current, then why the regular promotion of installing a relay? Does not seem to be necessary given the ampacity of the yellow wires involved. I never see the insulation on those wires cooked.
The main wire I see getting cooked is the black/purple tach wire on the ignition harnesses due to the mistake of reverse connecting to the coil with the black/red wire. |
| ctc911ctc |
Apr 16 2025, 05:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,329 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
Just thinking outloud.... there is no current limiting circuits within any old analog cars. As a result if there is a manufacturing error or just sloppy percision, having a rotor that connects and then arcs can cause large instantaneous amounts of current. Not sure what the impulse current is on the Solinoid of the starter - this also can go out of spec and start drawing more current than designed.............. These small things, over time can erode the copper connections - dead spots etc.........
May have to think about this a bit - (IMG:style_emoticons/default/dead horse.gif) Without excessive current, then why the regular promotion of installing a relay? Does not seem to be necessary given the ampacity of the yellow wires involved. I never see the insulation on those wires cooked. The main wire I see getting cooked is the black/purple tach wire on the ignition harnesses due to the mistake of reverse connecting to the coil with the black/red wire. |
| Superhawk996 |
Apr 16 2025, 08:13 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,823 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Not sure what the impulse current is on the Solinoid of the starter - this also can go out of spec and start drawing more current than designed.............. May have to think about this a bit - The OEM Bosch solenoid draws 25A. I’ve measured it on several starter solenoids using an accurate current shunt to make the measurement. This goes back to the mythology. As circuits, wiring, and solenoids age, resistance increases, voltage drops increase. This decreases current draw. Circuits don’t magically draw more current. Unless shorted and the smoke gets out but that is a whole different can of worms. |
| bdstone914 |
Apr 17 2025, 04:26 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,295 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Not sure what the impulse current is on the Solinoid of the starter - this also can go out of spec and start drawing more current than designed.............. May have to think about this a bit - The OEM Bosch solenoid draws 25A. I’ve measured it on several starter solenoids using an accurate current shunt to make the measurement. This goes back to the mythology. As circuits, wiring, and solenoids age, resistance increases, voltage drops increase. This decreases current draw. Circuits don’t magically draw more current. Unless shorted and the smoke gets out but that is a whole different can of worms. If it draws 25 amps you don't tonk it needs a relay? I think most other parts like horns, fog lights, fuel pumps that draw less current are on relays. I dont think turning the switch harder causes the cracking. Is a weak design with a cast hole for the coil spring end leads to cracking. I once examined 10 used switches and 9 were cracked. I believe in the relay. I have not opened up any but I bet the contact get pitting that leads to excess heat and switch failure. And most aftermarket switches seem to be junk. I know someone who dropped a new one on the carpet of the car and it shattered. Attached thumbnail(s) |
| Superhawk996 |
Apr 17 2025, 07:14 AM
If it draws 25 amps you don't tonk it needs a relay? I think most other parts like horns, fog lights, fuel pumps that draw less current are on relays. I dont think turning the switch harder causes the cracking. On the first point - I don’t think it’s fair to judge vintage cars by modern standards. Almost all cars of this vintage (both foreign and domestic) used high current switches for the starter and other things like headlamps, power windows, etc. The wiring and switch when new were sized appropriately to deal with the load. It’s the aging, voltage drops and the heat generated at high resistance junctions that are the root cause. I guess if we want to hold vintage cars to a modern standard we can say the high current switching is the root cause. On the second point about turning the key harder I was being a smart ass. It is what people do but I agree with you that isn’t what leads to the ignition switch housing cranking that is very common. I do think it is part of what contributes to the center “key” portion getting wallowed out. I’ve been around long enough to know that many people are still going to add the second relay. My main point is that it is unnecessary if the underlying system is sound (as designed) and that adding a second relay to control the first (ie the solenoid) is inelegant and is just another point of failure from a engineering Failure Mode Effects Analysis (FMEA) standpoint. And on a side note about being stranded by a failure to crank. BS. You can slide under the tail end and use a screwdriver, a tire iron, or even spare change to short the solenoid terminal to the B+ terminal and the engine can be started. Not fun. But . . . I have been there, done that. |
| GregAmy |
Apr 17 2025, 07:27 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,659 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
On the first point - I don’t think it’s fair to judge vintage cars by modern standards. I agree. But at the same time, I don't think it's fair to judge modern service and repair expectations by vintage design (unless you're shooting for Amelia center stage). I stand by "it's your car, you should do with it what you want". But relaying a vintage starter solenoid when using a vintage starter switch is just good standard practice. And it's easy and cheap to do. QUOTE You can slide under the tail end and use a screwdriver, a tire iron, or even spare change to short the solenoid terminal to the B+ terminal and the engine can be started. Ergo, your roadside repair is...relaying the solenoid. (IMG:style_emoticons/default/wink.gif) - GA |
JeffBowlsby Whats wrong with our ignition switches? Apr 16 2025, 03:29 PM
wonkipop
Regularly... Apr 16 2025, 03:51 PM
Root_Werks Similar here, replaced only one in a 914 over 35+ ... Apr 16 2025, 04:05 PM
wonkipop @JeffBowlsby
just asked mike#1.
911 switches pro... Apr 16 2025, 04:25 PM
Superhawk996
Without excessive current, then why the regular p... Apr 16 2025, 04:56 PM
ctc911ctc I only have my personal experience
1970 1.7 - in... Apr 16 2025, 05:05 PM
bkrantz My car came with a relay added to the starter, a p... Apr 16 2025, 07:39 PM
Jgilliam914
My car came with a relay added to the starter, a ... Apr 17 2025, 03:28 PM
Dlee6205 Replacing ignition switches has become standard pr... Apr 16 2025, 07:50 PM
Superhawk996 Well know fact . . . When it doesn’t start if yo... Apr 16 2025, 08:08 PM
davep It was about 1975 that I purchased a used 73 914. ... Apr 16 2025, 08:22 PM
Justinp71 I added a relay because even after a new switch, o... Apr 16 2025, 09:40 PM
Superhawk996 Greg - You’re right about the roadside “relay... Apr 17 2025, 07:36 AM
GregAmy Far too often it is used to Band-Aid underlying is... Apr 17 2025, 08:34 AM
Dave97 I have another problem I’ve been chasing. 1975 ... Apr 17 2025, 08:26 AM
Superhawk996
I have another problem I’ve been chasing. 1975... Apr 17 2025, 09:18 AM
TheCabinetmaker
I have another problem I’ve been chasing. 1975... Oct 3 2025, 04:37 AM
JeffBowlsby I have not had the electrical portion of the switc... Apr 17 2025, 09:24 AM
Dave97 I tried jb weld, let it dry and then put it togeth... Apr 17 2025, 09:31 AM
Superhawk996
I tried jb weld, let it dry and then put it toget... Apr 17 2025, 10:05 AM
Ishley I’ m on my 3rd switch in 2 yrs. The first one th... Apr 17 2025, 08:51 PM
orthobiz When I bought my 1974 1.8 in 2007, the ignition sw... Apr 18 2025, 06:55 AM
ConeDodger
Regularly... Apr 18 2025, 07:46 AM
chmillman Mine went out yesterday... There are a bunch of r... Sep 30 2025, 08:52 AM
Ishley I've had several go out in 2 years...
The iss... Sep 30 2025, 10:32 AM
tomeric914
I spoke to George at Auto Atlanta to complain abo... Oct 11 2025, 06:39 AM
Olympic 914
About 10 years ago, my switch failed. I was... Oct 11 2025, 07:03 AM
Superhawk996
For those that have melted switches, one thing th... Oct 11 2025, 07:27 AM
tomeric914
[b]@[url=http://www.914world.com/bbs2/index.php?s... Oct 11 2025, 06:20 PM
Superhawk996
[b]@[url=http://www.914world.com/bbs2/index.php?... Oct 12 2025, 11:31 AM
chmillman Local Porsche dealer just called and said my repla... Oct 2 2025, 04:52 AM
JeffBowlsby Avoid cutting any wires. Just remove the 50 wire ... Oct 2 2025, 09:02 AM
chmillman Thanks @JeffBowlsby , will do...
Here is the par... Oct 2 2025, 11:31 AM
trojanhorsepower I'll add my experience. Hugh and I tried to s... Oct 2 2025, 05:41 PM
DRPHIL914 my 2cents worth and experience with my 15 years of... Oct 8 2025, 12:45 PM
chmillman So got the Partworks switch in a couple of days ag... Oct 9 2025, 02:50 AM
DRPHIL914
So got the Partworks switch in a couple of days a... Oct 9 2025, 06:10 AM
chmillman
so one difference that I see is that the top pic... Oct 9 2025, 08:20 AM
DRPHIL914
[quote name='DRPHIL914' post='3227384' date='Oct ... Oct 10 2025, 11:03 AM
chmillman So, following the excellent Pelican Parts instruct... Oct 11 2025, 02:41 AM
chmillman So, since I had everything mostly apart anyway, ju... Oct 11 2025, 11:33 AM
Superhawk996
Wondering if I shouldn’t wire a relay from batt... Oct 11 2025, 12:10 PM
chmillman
Your problem and symptoms are indicating you hav... Oct 11 2025, 03:12 PM
Dave_Darling Your car is a 74, I see. I didn't read throug... Oct 11 2025, 03:43 PM
Superhawk996
Your car is a 74, I see. I didn't read throu... Oct 12 2025, 11:32 AM
chmillman IT'S FIXED...
OK, you guys are going to have ... Oct 12 2025, 11:35 AM
Superhawk996 Glad you’re back :driving: :Qarl: Oct 12 2025, 12:12 PM
StarBear Lesson learned and noted. Thanks!! Oct 12 2025, 02:23 PM
JamesJ So has it been determined that the $50 Porsch... Oct 20 2025, 07:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th April 2026 - 04:32 PM |
