| mmichalik |
Apr 17 2025, 07:12 PM
MikeM ![]() ![]() ![]() Group: Members Posts: 799 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California
Hi everyone,
My 75 is ready to drive again. I fixed the oil leak from the main seal a couple of weeks ago and all is good. As I continue to do the shake out of the car, since I'm on the tail end of the restoration, I've had one problem the entire time and I need to get it fixed now. Cold or hot, as I'm driving there's a flat spot when I shift between gears. It bogs and then picks up again. It's particularly noticeable from 1st to 2nd and 2nd to 3rd. Sometimes even when starting for a dead stop. I know NOTHING about carbs but I'm willing to jump in. Does anyone have any experience with these symptoms? Is there a write up on the world that I've missed? Would anyone be willing to work for high end craft beer and good pizza (along with an hourly rate) (IMG:style_emoticons/default/smile.gif) I'm in north county inland San Diego (Valley Center) Mike |
| porschetub |
Apr 17 2025, 10:49 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,109 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hi everyone, My 75 is ready to drive again. I fixed the oil leak from the main seal a couple of weeks ago and all is good. As I continue to do the shake out of the car, since I'm on the tail end of the restoration, I've had one problem the entire time and I need to get it fixed now. Cold or hot, as I'm driving there's a flat spot when I shift between gears. It bogs and then picks up again. It's particularly noticeable from 1st to 2nd and 2nd to 3rd. Sometimes even when starting for a dead stop. I know NOTHING about carbs but I'm willing to jump in. Does anyone have any experience with these symptoms? Is there a write up on the world that I've missed? Would anyone be willing to work for high end craft beer and good pizza (along with an hourly rate) (IMG:style_emoticons/default/smile.gif) I'm in north county inland San Diego (Valley Center) Mike You are most likely lean on the idle jets , check the size and IDF guys will step in cause I work on Dellorto's mainly but principles are similar . In the rev range you are talking about it will be pre transition to mains I would think. Supply some more details and you will be better off in the long run ,cheers. |
| mmichalik |
Apr 17 2025, 11:10 PM
Hi everyone, My 75 is ready to drive again. I fixed the oil leak from the main seal a couple of weeks ago and all is good. As I continue to do the shake out of the car, since I'm on the tail end of the restoration, I've had one problem the entire time and I need to get it fixed now. Cold or hot, as I'm driving there's a flat spot when I shift between gears. It bogs and then picks up again. It's particularly noticeable from 1st to 2nd and 2nd to 3rd. Sometimes even when starting for a dead stop. I know NOTHING about carbs but I'm willing to jump in. Does anyone have any experience with these symptoms? Is there a write up on the world that I've missed? Would anyone be willing to work for high end craft beer and good pizza (along with an hourly rate) (IMG:style_emoticons/default/smile.gif) I'm in north county inland San Diego (Valley Center) Mike You are most likely lean on the idle jets , check the size and IDF guys will step in cause I work on Dellorto's mainly but principles are similar . In the rev range you are talking about it will be pre transition to mains I would think. Supply some more details and you will be better off in the long run ,cheers. I'm not sure what's in there right now but I did purchase a bunch of idle jets from size .40 up to .65 so I could test that. I also bought a jet gauge and some jet reamers as well. I'm running the tangerine racing cable linkage and the engine started life as a 1.8 but is now a 1911 with a mild custom Schneider cam in it. let me know if there's any other info I can supply that might be useful |
mmichalik Weber 40 IDF help Apr 17 2025, 07:12 PM
technicalninja First thing I'd check is if the accelerator pu... Apr 17 2025, 07:23 PM
Superhawk996 What are you using for ignition? The reason I ask ... Apr 17 2025, 10:31 PM
mmichalik
What are you using for ignition? The reason I ask... Apr 17 2025, 11:00 PM
nditiz1 So 2 things will be needed, 1 of which is easy and... Apr 18 2025, 05:24 AM
Superhawk996
The 2nd item that is needed is an AFR gauge.
A... Apr 18 2025, 05:48 AM
930cabman
... Apr 18 2025, 09:51 AM
densible1 From my experience with 44 idf's and a bluetoo... Apr 18 2025, 10:49 AM
Superhawk996 One thing that is critical to tuning IDF’s is to... Apr 18 2025, 11:07 AM
nditiz1 A great tip that John from ACN told me was to remo... Apr 18 2025, 11:31 AM
dtmehall did the car ever run correctly with the webers and... Apr 18 2025, 12:45 PM
flxzcat Drilling new progression holes is a last resort an... Apr 18 2025, 04:26 PM
Superhawk996
Drilling new progression holes is a last resort a... Apr 18 2025, 07:10 PM
dtmehall if you want to investigate weber carb options cb p... Apr 18 2025, 05:08 PM
dtmehall :agree: Apr 18 2025, 07:35 PM
mmichalik Going to pull the emulsion tubes and idle jets to ... Apr 18 2025, 11:23 PM
Superhawk996 Need the Venturi size too!!
Very often th... Apr 19 2025, 05:38 AM
CCE
Hi everyone,
My 75 is ready to drive again. I fi... Apr 20 2025, 02:31 PM
mmichalik @porschetub
[b]@[url=http://www.914world.com/bbs... Apr 20 2025, 07:30 PM
Superhawk996
Venturi's are 32
Yeah that’s gonna’ suc... Apr 20 2025, 09:11 PM
mmichalik Just an FYI, my goal is to have a solid driver tha... Apr 21 2025, 08:46 AM
930cabman
Just an FYI, my goal is to have a solid driver th... Apr 21 2025, 11:38 AM
mmichalik
Just an FYI, my goal is to have a solid driver t... Apr 21 2025, 12:30 PM
VaccaRabite
Just an FYI, my goal is to have a solid driver th... Apr 21 2025, 01:19 PM
Superhawk996 Pick your Venturi 1st
Then general rule of thumb... Apr 21 2025, 09:52 AM
mmichalik OK, I'm going in today. :) Changing the vent... Apr 27 2025, 10:35 AM
mmichalik Just finished changing the venturi's, they wer... Apr 27 2025, 12:53 PM
porschetub
Just finished changing the venturi's, they we... Apr 27 2025, 07:32 PM
mmichalik Drove it. Venturi's made a huge difference, n... Apr 27 2025, 04:39 PM
930cabman
Drove it. Venturi's made a huge difference, ... Apr 27 2025, 05:33 PM
Eric_Shea Put 28's in it.
We have a jetting spreadsheet... May 1 2025, 01:42 PM
930cabman Invest in Pat Bradens book, Weber Carburators May 1 2025, 06:05 PM
mmichalik @Eric_Shea Agreed, they made a HUGE difference to... May 2 2025, 11:41 AM
930cabman
[b]@[url=http://www.914world.com/bbs2/index.php?s... May 2 2025, 04:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th May 2026 - 02:26 PM |
