> Weber 40 IDF help, My usual guy had back surgery and can't help now
mmichalik
post Apr 17 2025, 07:12 PM
MikeM
Hi everyone,
My 75 is ready to drive again. I fixed the oil leak from the main seal a couple of weeks ago and all is good.
As I continue to do the shake out of the car, since I'm on the tail end of the restoration, I've had one problem the entire time and I need to get it fixed now.
Cold or hot, as I'm driving there's a flat spot when I shift between gears. It bogs and then picks up again.
It's particularly noticeable from 1st to 2nd and 2nd to 3rd. Sometimes even when starting for a dead stop.
I know NOTHING about carbs but I'm willing to jump in.
Does anyone have any experience with these symptoms? Is there a write up on the world that I've missed?
Would anyone be willing to work for high end craft beer and good pizza (along with an hourly rate) (IMG:style_emoticons/default/smile.gif) I'm in north county inland San Diego (Valley Center)
Mike
nditiz1
post Apr 18 2025, 05:24 AM
So 2 things will be needed, 1 of which is easy and the other will require a purchase and some welding (well they do make a bolt on bung)
1st we need to know what jets are in there now. Pull one from the side (idle jet), pull the top stack (main, air, emulsion). If these are brand new Weber IDF or even old stock ones you are probably running something like this:
50 idle
115 main
180/200 air (can't remember which one came factory)
F11 emulsion
28mm venturis
The 2nd item that is needed is an AFR gauge. I usually use an AEM UEOG wideband, but you can use whichever you like. They even have a fancy bluetooth one that shows on your phone so no need for an additional pod. You will need to have a bung welded into your muffler or exhaust. Preferably both sides, but one in the muffler should suffice. There is another option in LM2 (if memory serves) that connects to the end of the muffler tip to get a reading on AFR. Never used that one.
OR you can just keep making minor changes until it "feels" right, but you could be overly rich and not know it.
Superhawk996
post Apr 18 2025, 05:48 AM
QUOTE(nditiz1 @ Apr 18 2025, 07:24 AM) *
Awfully nice to have but not a must have. There were no affordable AFR gauges back in the day and we got by just fine reading plugs, using the assometer, CHT’s, and monitoring fuel economy.
Glad to hear the ignition is 123 - makes life a whole lot easier.
Per Porschetub’s comment above, need a whole lot more detail on speed, RPM ranges, throttle position, and load (flat vs hill) to advise. Your gut instinct is correct; it is a lot easier if you can find someone local that has carb tuning experience vs doing it via internet advice.
Regardless of how you go about this - I highly suggest you keep a journal / logbook. Time / date, temperatures, jetting changes, ignition advance curve used, CHT’s, any details. Things can get very murky after a few days. Humans are not terribly good at recalling how one change vs another felt after only a few hours between changes. Doesn’t need to be overly fancy or complicated but document your baseline and what changes you make.
930cabman
post Apr 18 2025, 09:51 AM
QUOTE(Superhawk996 @ Apr 18 2025, 05:48 AM) *
All good information and try to make just ONE change at a time to keep things in order
mmichalik   Weber 40 IDF help   Apr 17 2025, 07:12 PM
technicalninja   First thing I'd check is if the accelerator pu...   Apr 17 2025, 07:23 PM
Superhawk996   What are you using for ignition? The reason I ask ...   Apr 17 2025, 10:31 PM
mmichalik   What are you using for ignition? The reason I ask...   Apr 17 2025, 11:00 PM
porschetub   Hi everyone, My 75 is ready to drive again. I fi...   Apr 17 2025, 10:49 PM
mmichalik   Hi everyone, My 75 is ready to drive again. I f...   Apr 17 2025, 11:10 PM
nditiz1   So 2 things will be needed, 1 of which is easy and...   Apr 18 2025, 05:24 AM
Superhawk996   The 2nd item that is needed is an AFR gauge. A...   Apr 18 2025, 05:48 AM
930cabman   The 2nd item that is needed is an AFR gauge. ...   Apr 18 2025, 09:51 AM
densible1   From my experience with 44 idf's and a bluetoo...   Apr 18 2025, 10:49 AM
Superhawk996   One thing that is critical to tuning IDF’s is to...   Apr 18 2025, 11:07 AM
nditiz1   A great tip that John from ACN told me was to remo...   Apr 18 2025, 11:31 AM
dtmehall   did the car ever run correctly with the webers and...   Apr 18 2025, 12:45 PM
flxzcat   Drilling new progression holes is a last resort an...   Apr 18 2025, 04:26 PM
Superhawk996   Drilling new progression holes is a last resort a...   Apr 18 2025, 07:10 PM
dtmehall   if you want to investigate weber carb options cb p...   Apr 18 2025, 05:08 PM
dtmehall   :agree:   Apr 18 2025, 07:35 PM
mmichalik   Going to pull the emulsion tubes and idle jets to ...   Apr 18 2025, 11:23 PM
Superhawk996   Need the Venturi size too!! Very often th...   Apr 19 2025, 05:38 AM
CCE   Hi everyone, My 75 is ready to drive again. I fi...   Apr 20 2025, 02:31 PM
mmichalik   @porschetub [b]@[url=http://www.914world.com/bbs...   Apr 20 2025, 07:30 PM
Superhawk996   Venturi's are 32 Yeah that’s gonna’ suc...   Apr 20 2025, 09:11 PM
mmichalik   Just an FYI, my goal is to have a solid driver tha...   Apr 21 2025, 08:46 AM
930cabman   Just an FYI, my goal is to have a solid driver th...   Apr 21 2025, 11:38 AM
mmichalik   Just an FYI, my goal is to have a solid driver t...   Apr 21 2025, 12:30 PM
VaccaRabite   Just an FYI, my goal is to have a solid driver th...   Apr 21 2025, 01:19 PM
Superhawk996   Pick your Venturi 1st Then general rule of thumb...   Apr 21 2025, 09:52 AM
mmichalik   OK, I'm going in today. :) Changing the vent...   Apr 27 2025, 10:35 AM
mmichalik   Just finished changing the venturi's, they wer...   Apr 27 2025, 12:53 PM
porschetub   Just finished changing the venturi's, they we...   Apr 27 2025, 07:32 PM
mmichalik   Drove it. Venturi's made a huge difference, n...   Apr 27 2025, 04:39 PM
930cabman   Drove it. Venturi's made a huge difference, ...   Apr 27 2025, 05:33 PM
Eric_Shea   Put 28's in it. We have a jetting spreadsheet...   May 1 2025, 01:42 PM
930cabman   Invest in Pat Bradens book, Weber Carburators   May 1 2025, 06:05 PM
mmichalik   @Eric_Shea Agreed, they made a HUGE difference to...   May 2 2025, 11:41 AM
930cabman   [b]@[url=http://www.914world.com/bbs2/index.php?s...   May 2 2025, 04:10 PM
- Lo-Fi Version Time is now: 25th May 2026 - 02:31 PM
