> Weber 40 IDF help, My usual guy had back surgery and can't help now
mmichalik
post Apr 17 2025, 07:12 PM
MikeM
Hi everyone,
My 75 is ready to drive again. I fixed the oil leak from the main seal a couple of weeks ago and all is good.
As I continue to do the shake out of the car, since I'm on the tail end of the restoration, I've had one problem the entire time and I need to get it fixed now.
Cold or hot, as I'm driving there's a flat spot when I shift between gears. It bogs and then picks up again.
It's particularly noticeable from 1st to 2nd and 2nd to 3rd. Sometimes even when starting for a dead stop.
I know NOTHING about carbs but I'm willing to jump in.
Does anyone have any experience with these symptoms? Is there a write up on the world that I've missed?
Would anyone be willing to work for high end craft beer and good pizza (along with an hourly rate) (IMG:style_emoticons/default/smile.gif) I'm in north county inland San Diego (Valley Center)
Mike
flxzcat
post Apr 18 2025, 04:26 PM
Drilling new progression holes is a last resort and not for the home mechanic unless you have a mill to put them in a precise location in each barrel.
Spanish version Weber 45 DCOE's of the mid 2000's were notorious for this particular progression problem and the only solution was to drill an extra progression hole exactly like the original Italian 45's.
You might Google for pictures of 40IDF progression holes in an original Italian version and compare to your carbs.
Superhawk996
post Apr 18 2025, 07:10 PM
QUOTE(flxzcat @ Apr 18 2025, 06:26 PM) *
There is no need to drill anything on IDF’s to get them tuned for a 914.
mmichalik   Weber 40 IDF help   Apr 17 2025, 07:12 PM
technicalninja   First thing I'd check is if the accelerator pu...   Apr 17 2025, 07:23 PM
Superhawk996   What are you using for ignition? The reason I ask ...   Apr 17 2025, 10:31 PM
mmichalik   What are you using for ignition? The reason I ask...   Apr 17 2025, 11:00 PM
porschetub   Hi everyone, My 75 is ready to drive again. I fi...   Apr 17 2025, 10:49 PM
mmichalik   Hi everyone, My 75 is ready to drive again. I f...   Apr 17 2025, 11:10 PM
nditiz1   So 2 things will be needed, 1 of which is easy and...   Apr 18 2025, 05:24 AM
Superhawk996   The 2nd item that is needed is an AFR gauge. A...   Apr 18 2025, 05:48 AM
930cabman   The 2nd item that is needed is an AFR gauge. ...   Apr 18 2025, 09:51 AM
densible1   From my experience with 44 idf's and a bluetoo...   Apr 18 2025, 10:49 AM
Superhawk996   One thing that is critical to tuning IDF’s is to...   Apr 18 2025, 11:07 AM
nditiz1   A great tip that John from ACN told me was to remo...   Apr 18 2025, 11:31 AM
dtmehall   did the car ever run correctly with the webers and...   Apr 18 2025, 12:45 PM
flxzcat   Drilling new progression holes is a last resort an...   Apr 18 2025, 04:26 PM
Superhawk996   Drilling new progression holes is a last resort a...   Apr 18 2025, 07:10 PM
dtmehall   if you want to investigate weber carb options cb p...   Apr 18 2025, 05:08 PM
dtmehall   :agree:   Apr 18 2025, 07:35 PM
mmichalik   Going to pull the emulsion tubes and idle jets to ...   Apr 18 2025, 11:23 PM
Superhawk996   Need the Venturi size too!! Very often th...   Apr 19 2025, 05:38 AM
CCE   Hi everyone, My 75 is ready to drive again. I fi...   Apr 20 2025, 02:31 PM
mmichalik   @porschetub [b]@[url=http://www.914world.com/bbs...   Apr 20 2025, 07:30 PM
Superhawk996   Venturi's are 32 Yeah that’s gonna’ suc...   Apr 20 2025, 09:11 PM
mmichalik   Just an FYI, my goal is to have a solid driver tha...   Apr 21 2025, 08:46 AM
930cabman   Just an FYI, my goal is to have a solid driver th...   Apr 21 2025, 11:38 AM
mmichalik   Just an FYI, my goal is to have a solid driver t...   Apr 21 2025, 12:30 PM
VaccaRabite   Just an FYI, my goal is to have a solid driver th...   Apr 21 2025, 01:19 PM
Superhawk996   Pick your Venturi 1st Then general rule of thumb...   Apr 21 2025, 09:52 AM
mmichalik   OK, I'm going in today. :) Changing the vent...   Apr 27 2025, 10:35 AM
mmichalik   Just finished changing the venturi's, they wer...   Apr 27 2025, 12:53 PM
porschetub   Just finished changing the venturi's, they we...   Apr 27 2025, 07:32 PM
mmichalik   Drove it. Venturi's made a huge difference, n...   Apr 27 2025, 04:39 PM
930cabman   Drove it. Venturi's made a huge difference, ...   Apr 27 2025, 05:33 PM
Eric_Shea   Put 28's in it. We have a jetting spreadsheet...   May 1 2025, 01:42 PM
930cabman   Invest in Pat Bradens book, Weber Carburators   May 1 2025, 06:05 PM
mmichalik   @Eric_Shea Agreed, they made a HUGE difference to...   May 2 2025, 11:41 AM
930cabman   [b]@[url=http://www.914world.com/bbs2/index.php?s...   May 2 2025, 04:10 PM
- Lo-Fi Version Time is now: 25th May 2026 - 02:29 PM
