> What lube should I use.....
Jamie
post Apr 8 2025, 07:54 AM
....on a 73 teener speedometer cable? My speedo quit working last fall on the way home from Okteenerfest , and I'm going to pull it for repairs, and WIAI I'll lube related parts. (IMG:style_emoticons/default/rolleyes.gif)
ClayPerrine
post Apr 24 2025, 10:52 AM
Years ago I was broke and needed to fix the speedo cable on my 914 before I got a ticket. So I took the speedo cable and made an adapter to hook the speedometer end to a 2L bottle. Made a way to hang it up out of a coat hanger. Then I cut a hole in the bottom and filled it full of liquid B12. Hung it up for a week with a bucket on the transmission end of the cable. After a week I refilled the bottle with motor oil, and let it sit for a week. The cable worked fine after that.
But honestly, that is way too much work for something I can buy relatively inexpensively. It is all about time vs money. Which do you have more of these days?
Jamie
post Apr 24 2025, 10:58 AM
QUOTE(ClayPerrine @ Apr 24 2025, 08:52 AM) *
I'm informed that there are tabs located in the tunnel that hold the cable in place, and that fishing a new cable is no fun. Old cable was not jerky when the speedo died, has 58K mi. of use, so I'm hoping to avoid the fishing expedition to install a new cable if it is the drive that is at fault. I've already bought a new cable from 914 Rubber just in case. (IMG:style_emoticons/default/chowtime.gif)
- Lo-Fi Version Time is now: 1st September 2025 - 05:00 AM
