| Osnabruck914 |
Apr 24 2025, 04:36 PM
Member ![]() ![]() Group: Members Posts: 184 Joined: 19-December 22 From: United States Member No.: 27,038 Region Association: South East States |
914-4 2.0 Liter Engine
In the engine compartment looking backwards towards the rear of the car, there is a view port at about the eleven o'clock position of the bell housing through which you can see about an inch or so of the outer extremity of the flywheel. There is a perfectly machined dime-sized hole in that area of the flywheel that passes by that port as you spin the flywheel. When at TDC for Cylinder #1 that hole just starts to appear at the edge of the view port. It is not centered to it. What is it for? Is it another TDC reference, which I doubt, as it is a relatively large hole and does not center to that view port. Is it where material was removed to balance the flywheel? When I adjust my valves I use the factory scribe mark on the circumference edge of the flywheel, plus another mark I painted 180 degrees opposite, plus a 0 degree mark I have on the fan to determine TDC points. So I am puzzled by this hole in the flywheel. Probably a stupid question, but I sure want know. Osnabruck914 |
| ClayPerrine |
Apr 25 2025, 05:22 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
The hole is there to access the bolts for the torque converter in a VW automatic stick shift VW 411/412. The 914 used the same base casting of the engine cases. It's the same reason we have the mounting pads for a mechanical fuel pump, but they have never been machined.
Osnabruck914 Purpose Of Hole In Edge Of Flywheel Apr 24 2025, 04:36 PM
brant It should be a area where they removed a little bi... Apr 24 2025, 04:38 PM
fixer34 Yep, balance. Think of it the same way as when th... Apr 24 2025, 04:50 PM
Osnabruck914 Thanks all. I kinda figured it was that. I was a... Apr 24 2025, 04:57 PM
JamesM There is a plastic plug that covers that hole.
... Apr 24 2025, 10:13 PM
ctc911ctc
There is a plastic plug that covers that hole. ... Apr 25 2025, 06:42 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th December 2025 - 01:20 PM |
