| RTz |
Mar 21 2025, 10:35 AM
Newbie ![]() Group: Members Posts: 26 Joined: 18-October 24 From: Oregon City Member No.: 28,424 Region Association: None |
The primary goal was to add a pair of VDO gauges without the need for drilling or otherwise modifying the car. This gauge pod slides into the ashtray rails, no fasteners or drilling holes required, as well as easy access to wiring. Designed for 52mm VDO gauges only.
I originally designed this for Fixer34 and it has since gone through a number of revisions, one of them being the early dash is slightly different than my later '72 dash. This latest version will fit both. Also printing methods have improved to print a much nicer final finish. A couple of notes: 1) I think it's reasonable to describe these as "unfinished". 3D Printing is an imperfect process. There are minor blems in each one. Fine to use as-is, but If you want a truly finished part a modest amount of sanding/filing and filler primer/painting will be required for a flawless finish. 2) There is a limit to how hot you can allow the plastic to get before deforming. These are printed with PETG and is generally fine to around 130-ish degrees. If you live in a hot climate and keep the windows closed, the interior of a car can exceed 130. I've made a total of 3, with one of them going to Fixer34, so I have two left that are available for purchase. $65 each plus $19 shipping anywhere in the contiguous US. PM if you would like one. If there is sufficient interest I'll see about making a few more. ![]() ![]() ![]() ![]() ![]() ![]() |
| RTz |
Apr 11 2025, 08:53 AM
Final bump
| Ron914 |
Apr 25 2025, 09:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 562 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
Final bump @RTz I might be interested in one of these if you make any more ,How much are you asking ? PM me if you do .Oh I see VDO 52mm gauges only ,will it except another brand 52mm gauge ? Thanks Ron914 |
| RTz |
Apr 26 2025, 07:33 AM
@RTz I might be interested in one of these if you make any more ,How much are you asking ? PM me if you do .Oh I see VDO 52mm gauges only ,will it except another brand 52mm gauge ? Hi Ron914, I would be very surprised if anything other than VDO gauges would fit. However, if you want to shoot me a DM with some basic measurements: diameter of the body, depth, stud spacing, etc, I will check to see if its close, and if it is, I’ll send you one to try out. |
| Ron914 |
Apr 26 2025, 01:31 PM
@RTz I might be interested in one of these if you make any more ,How much are you asking ? PM me if you do .Oh I see VDO 52mm gauges only ,will it except another brand 52mm gauge ? Hi Ron914, I would be very surprised if anything other than VDO gauges would fit. However, if you want to shoot me a DM with some basic measurements: diameter of the body, depth, stud spacing, etc, I will check to see if its close, and if it is, I’ll send you one to try out. I tried to check the size /specifications but my VDO vacuum gauge only says 52mm, My AEM AFR gauge also says 52mm and the Dakota Digital says 52mm/2 1/16 which is 2.0625" The depth of the AFR is quite shallow, see photo . The Dakota Digital specs |
RTz FS: Double VDO Gauge Pods Mar 21 2025, 10:35 AM
Dynosoar11 I would like one.
PM me with payment info please.
... Mar 21 2025, 02:33 PM
RTz
I would like one.
PM me with payment info please.... Mar 21 2025, 02:51 PM
RTz One more available. Mar 25 2025, 12:33 PM
bahnzai I’ll take the other one. PM the details to send ... Mar 25 2025, 02:33 PM
fixer34 Got mine yesterday, haven't had a chance to tr... Mar 27 2025, 05:09 PM
PCA7GGR If you do more of those consider angling the gauge... Mar 27 2025, 05:44 PM
RTz Great Fixer34, thank you for the feedback!
S... Mar 28 2025, 05:36 AM
RTz Two more are available and am expecting to print a... Mar 31 2025, 06:09 AM
RTz Bump Apr 5 2025, 08:40 AM
Nein For Teens I don't know if I have any credibility here . ... Apr 25 2025, 10:02 PM
Ron914
I don't know if I have any credibility here .... Apr 26 2025, 07:32 AM
RTz
I don't know if I have any credibility here .... Apr 26 2025, 07:35 AM
fixer34 I was the one that Ron initially made this for. Fi... Apr 26 2025, 08:58 PM
Ron914
I was the one that Ron initially made this for. F... May 4 2025, 01:44 PM
RTz Thank you @Fixer34 , that is kind of you.
[b]@... Apr 27 2025, 08:43 AM
Ron914
Thank you @[url=http://www.914world.com/bbs2/ind... Apr 27 2025, 08:05 PM
Ron914
[quote name='RTz' post='3202992' date='Apr 27 202... Apr 30 2025, 12:25 PM
RTz
Just to confirm I am interested in purchasing one... Apr 30 2025, 12:46 PM
Ron914
Just to confirm I am interested in purchasing on... Apr 30 2025, 07:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th October 2026 - 08:37 PM |
