| bajafreaks |
Apr 26 2025, 12:35 PM
Member ![]() ![]() Group: Members Posts: 189 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California |
I'm quite aways from having my engine completed but just wondering if there is any big advantage to pre running it before installing. It will be on carbs.
| technicalninja |
Apr 26 2025, 12:52 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
Absolutely!
Especially a fresh engine! Bunch easier to re-adjust valves and re-torque head nuts after first full heat cycle if the puppy is out of chassis. Oil leaks are easier to spot/fix. Good/bad memories will be made... |
| bajafreaks |
Apr 26 2025, 01:41 PM
Absolutely! Especially a fresh engine! Bunch easier to re-adjust valves and re-torque head nuts after first full heat cycle if the puppy is out of chassis. Oil leaks are easier to spot/fix. Good/bad memories will be made... Kinda what i was thinking, exactly. I guess it cant be that difficult to hook up a temp fuel pump, battery, etc. The transmission would be attached anyway before installing into the car. Is there anything I'm missing? |
bajafreaks Pre run engine before installing Apr 26 2025, 12:35 PM
mepstein We run almost all our engines on a test stand befo... Apr 26 2025, 03:07 PM
bajafreaks
We run almost all our engines on a test stand bef... Apr 27 2025, 09:01 AM
Jack Standz Yes, a couple ratchet straps and a pallet works.
... Apr 27 2025, 06:06 AM
NARP74 This guy makes some stuff that helps. Maybe if yo... Apr 27 2025, 12:40 PM
930cabman In addition, I prime the oil system by cranking it... Apr 27 2025, 12:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 12:11 AM |
