shag |
Member ![]() ![]() Group: Members Posts: 84 Joined: 18-January 14 From: mount wolf pa Member No.: 16,901 Region Association: North East States ![]() ![]() |
Hey, I removed my fuel tank, had it blasted and am trying to re-install it. BUT there is a blockage in the larger (of the two) fuel lines. It seems to have been there since new?The vehicle is a late '73 and to the best of my knowledge looks like it is original. How am I suppose to insert a (maybe) 3" long screen into this fuel outlet with this circular thing approximately 1/2" inside there? I am trying to get the car up and running to make to the Porsche Swap Meet next weekend.
Thanks for your help. |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,221 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
That side with the restriction closest to the weld flange is for the return line.
The filter sock goes into the hole that is completely open into the tank. ![]() ![]() And ditch the teflon tape on the threads. The seal is established by fiber washers as shown in PET. Fiber washers are available at Harbor Freight, Amazon, Granger, etc. Use the right parts and you won’t have leaks. The teflon tape on the threads won’t do anything to seal the tank. |
shag |
Yup, Peter Egan is right. I did not remove the tubing, the mechanic at the shop did that. My mistake was looking at the tubing and trying to install it without knowing which port it came from. The screen would not fit into the smaller size port easily causing me to believe it came from larger port. After fooling around for quite a while Ed figured it out!
Now how about the rubber spacers, can anyone tell me exactly how or where they go? |
fiacra |
Person.Woman.Man.Camera.TV ![]() ![]() ![]() Group: Members Posts: 578 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California ![]() ![]() |
Yup, Peter Egan is right. I did not remove the tubing, the mechanic at the shop did that. My mistake was looking at the tubing and trying to install it without knowing which port it came from. The screen would not fit into the smaller size port easily causing me to believe it came from larger port. After fooling around for quite a while Ed figured it out! Now how about the rubber spacers, can anyone tell me exactly how or where they go? Glad the problem with the strainer got solved! Rubber spacers? Not sure what you are talking about. Perhaps the "rubber buffers" on the side of the tank (#2 and #3 in the diagram posted by hndyhrr)? It can be helpful to consult the PET and look at the diagrams if you are unsure how something goes together. Go to the tech notes section on Jeff Bowlsby's website and you'll find a link to the PET. Or, here's a direct link: https://bowlsby.net/914/Classic/zTN_Man01C.pdf Again, a picture of things you are asking about is the best way to get a direct and helpful answer (as you just found out). Putting pictures in is quite easy. When in doubt on how to do something, go to the FAQ section on this website. Here's a link to the instructions on putting pictures in your post: http://www.914world.com/bbs2/index.php?showtopic=13637 |
Lo-Fi Version | Time is now: 15th July 2025 - 01:11 AM |
