| s13u74cr4 |
Apr 26 2025, 04:16 PM
Member ![]() ![]() Group: Members Posts: 54 Joined: 2-September 23 From: PNW Member No.: 27,558 Region Association: Pacific Northwest |
After last post where I asked if I should pull the tank given all the new hoses I put in in the back, I am pretty surprised at how clean it is!!
But, I spot a few issues. Obviously fuel clamp is doing nothing. That line appears older/unreplaced. And, the line was crimped under the tank on that ridge. I could sort of tell that from above, but it’s worse. See anything else? |
| 914sgofast2 |
Apr 26 2025, 04:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 814 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
I would replace those cloth/fiber or carpet pads under the gas tank with rubber ones that won't get waterlogged and cause the gas tank to rust out. In my experience, 914 gas tanks will develop pin hole leaks from where those cloth/fiber pads rest on the body or are glued to the gas tank itself. I have seen that happen on 3 gas tanks. The pin holes in the tank typically results in a strong gas fume smell in the car's passenger cabin whenever the gas tank is filled up, and lingers until the tank is half full or less. People spend hours trying to find the source of the gas smell and spend a lot of time replacing fuel hoses and the vapor canister system's parts, because they never see any actual liquid gas on the ground under the car.
s13u74cr4 Pulled my tank, how may problems do you see? Apr 26 2025, 04:16 PM
Craigers17 It looks great to me. Clean, dry, nice paint, nic... Apr 26 2025, 04:27 PM
s13u74cr4 PO did put SS in the tunnel. Loose clamp was at th... Apr 26 2025, 11:35 PM
Craigers17 If you remove the steering rack cover from underne... Apr 27 2025, 04:31 AM
bkrantz The large center hole is indeed for access. if yo... Apr 27 2025, 07:37 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd October 2026 - 05:59 PM |
