> 914World Classifieds Rules
> FS: Double VDO Gauge Pods, Ashtray Mounted
RTz
post Mar 21 2025, 10:35 AM
The primary goal was to add a pair of VDO gauges without the need for drilling or otherwise modifying the car. This gauge pod slides into the ashtray rails, no fasteners or drilling holes required, as well as easy access to wiring. Designed for 52mm VDO gauges only.
I originally designed this for Fixer34 and it has since gone through a number of revisions, one of them being the early dash is slightly different than my later '72 dash. This latest version will fit both. Also printing methods have improved to print a much nicer final finish.
A couple of notes:
1) I think it's reasonable to describe these as "unfinished". 3D Printing is an imperfect process. There are minor blems in each one. Fine to use as-is, but If you want a truly finished part a modest amount of sanding/filing and filler primer/painting will be required for a flawless finish.
2) There is a limit to how hot you can allow the plastic to get before deforming. These are printed with PETG and is generally fine to around 130-ish degrees. If you live in a hot climate and keep the windows closed, the interior of a car can exceed 130.
I've made a total of 3, with one of them going to Fixer34, so I have two left that are available for purchase. $65 each plus $19 shipping anywhere in the contiguous US. PM if you would like one.
If there is sufficient interest I'll see about making a few more.
fixer34
post Apr 26 2025, 08:58 PM
I was the one that Ron initially made this for. Finally got around to installing mine yesterday (only been a month..) and it looks like a factory option.
Design point on it was to use the 52mm VDO gauges with the 2 long mounting scews attached to the back of the gauges (NOT centered), and allow access to connections/bulbs.
The 'sockets' are 30mm deep so I would think most any 52mm gauge would fit. The question would be securing it in place.
By the way, the gauges are easily visible just as they are; trying to make it a tilt mounting won't work due to the tight spacing of the ashtray opening.
I also have the prototype build. It is a little 'rougher' so needs some finishing, and fits '72 or later with the wider ashtray dash opening (something else we discovered-'70 & '71 are narrower). If anyone is interested, I'll mail it to you and then you send Ron something for it.
Pete
RTz   FS: Double VDO Gauge Pods   Mar 21 2025, 10:35 AM
Dynosoar11   I would like one. PM me with payment info please. ...   Mar 21 2025, 02:33 PM
RTz   I would like one. PM me with payment info please....   Mar 21 2025, 02:51 PM
RTz   One more available.   Mar 25 2025, 12:33 PM
bahnzai   I’ll take the other one. PM the details to send ...   Mar 25 2025, 02:33 PM
fixer34   Got mine yesterday, haven't had a chance to tr...   Mar 27 2025, 05:09 PM
PCA7GGR   If you do more of those consider angling the gauge...   Mar 27 2025, 05:44 PM
RTz   Great Fixer34, thank you for the feedback! S...   Mar 28 2025, 05:36 AM
RTz   Two more are available and am expecting to print a...   Mar 31 2025, 06:09 AM
RTz   Bump   Apr 5 2025, 08:40 AM
RTz   Final bump   Apr 11 2025, 08:53 AM
Ron914   Final bump @RTz I might be interested in one o...   Apr 25 2025, 09:27 PM
RTz   [b]@[url=http://www.914world.com/bbs2/index.php?...   Apr 26 2025, 07:33 AM
Ron914   [b]@[url=http://www.914world.com/bbs2/index.php...   Apr 26 2025, 01:31 PM
Nein For Teens   I don't know if I have any credibility here . ...   Apr 25 2025, 10:02 PM
Ron914   I don't know if I have any credibility here ....   Apr 26 2025, 07:32 AM
RTz   I don't know if I have any credibility here ....   Apr 26 2025, 07:35 AM
fixer34   I was the one that Ron initially made this for. Fi...   Apr 26 2025, 08:58 PM
Ron914   I was the one that Ron initially made this for. F...   May 4 2025, 01:44 PM
RTz   Thank you @Fixer34 , that is kind of you. [b]@...   Apr 27 2025, 08:43 AM
Ron914   Thank you @[url=http://www.914world.com/bbs2/ind...   Apr 27 2025, 08:05 PM
Ron914   [quote name='RTz' post='3202992' date='Apr 27 202...   Apr 30 2025, 12:25 PM
RTz   Just to confirm I am interested in purchasing one...   Apr 30 2025, 12:46 PM
Ron914   Just to confirm I am interested in purchasing on...   Apr 30 2025, 07:24 PM
- Lo-Fi Version Time is now: 24th October 2026 - 08:37 PM
