> Pulled my tank, how may problems do you see?
s13u74cr4
post Apr 26 2025, 04:16 PM
After last post where I asked if I should pull the tank given all the new hoses I put in in the back, I am pretty surprised at how clean it is!!
But, I spot a few issues. Obviously fuel clamp is doing nothing. That line appears older/unreplaced. And, the line was crimped under the tank on that ridge. I could sort of tell that from above, but it’s worse.
See anything else?
bkrantz
post Apr 27 2025, 07:37 PM
The large center hole is indeed for access. if you plump the tank and fuel filters with long lines, you can pull the filter out through the hole, and replace it without removing the tank.
- Lo-Fi Version Time is now: 2nd October 2026 - 05:58 PM
