| Ron914 |
Apr 28 2025, 10:52 PM
Member ![]() ![]() Group: Members Posts: 468 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
I needed to rebuild my MPS but Chris Foley is out of the kits due to no longer having a supplier of the BE-CU diaphragms . I was lucky enough to have a member here offer to sell me his spare parts kit from Chris (Thanks Tom). His kit did not have the instructions with it so I am wondering if anyone has a copy of those instructions?
| emerygt350 |
Apr 30 2025, 04:33 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,423 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I agree. I think anders is really doing the deep dive, which is great, but you don't need to overthink it. It is three adjustments and you can watch the outcome yourself.
The initial setup is easy, just do as Chris says, then check the curve to make sure it has the right shape, pop it in the car and tweak the inner and full stop till it is doing what you need. And you don't want it leaking. Not only does that make initial setup and idle difficult, but a small leak probably means a cracked diaphragm and that will break as you start to actually drive it and stress it. When I bought mine it went from running good enough to broken diaphragm pretty quick as I was daily driving it. And ignore the inductance numbers themselves. You just want to make sure the curve looks right you just want to plot the inductance at each inhg increase or decrease in vacuum. |
Ron914 CFR MPS rebuild Apr 28 2025, 10:52 PM
MDTerp RE: CFR MPS rebuild Apr 29 2025, 04:26 AM
Ron914
Thank you Michael. @[url=http://www.914world.c... Apr 29 2025, 08:27 AM
rjames The hex tool is used in conjunction with the screw... Apr 29 2025, 08:50 AM
Ron914
The hex tool is used in conjunction with the scre... Apr 29 2025, 09:31 AM
ChrisFoley The reason I recommend using those smaller taps as... Apr 29 2025, 08:54 AM
ChrisFoley That's an old tool set pictured. Currently, I ... Apr 29 2025, 08:57 AM
ChrisFoley Hi Ron,
I was just on the phone with Tom yesterday... Apr 29 2025, 09:05 AM
Ron914
Hi Ron,
I was just on the phone with Tom yesterda... Apr 29 2025, 09:34 AM
emerygt350 Those look like good improvements on an already gr... Apr 29 2025, 09:49 AM
rjames
Don't overthink it. If both sizes are in the... Apr 29 2025, 10:10 AM
ChrisFoley I've been including M4 screws & nuts for a... Apr 29 2025, 10:37 AM
MDTerp For me it was also very helpful to install a vacuu... Apr 29 2025, 01:05 PM
emerygt350
For me it was also very helpful to install a vacu... Apr 29 2025, 03:20 PM
Ron914
For me it was also very helpful to install a vac... May 1 2025, 07:35 AM
emerygt350
[quote name='emerygt350' post='3203360' date='Apr... May 1 2025, 09:34 AM
Ron914
[quote name='emerygt350' post='3203360' date='Ap... May 1 2025, 11:37 AM
TargaToy Well crap. I didn’t realize there was no longer... Apr 29 2025, 07:09 PM
Ron914
Well crap. I didn’t realize there was no longe... Apr 29 2025, 07:47 PM
emerygt350 I believe Chris is looking for a replacement. Apr 29 2025, 07:29 PM
Ron914 After reading a bit of Paul Anders MPS Diagnosis I... Apr 29 2025, 08:48 PM
JeffBowlsby
After reading a bit of Paul Anders MPS Diagnosis ... Apr 29 2025, 10:08 PM
Ron914
I agree. I think anders is really doing the dee... Apr 30 2025, 06:18 PM
worn
I needed to rebuild my MPS but Chris Foley is out... Apr 30 2025, 05:30 PM
Ron914
I needed to rebuild my MPS but Chris Foley is ou... Apr 30 2025, 05:41 PM
emerygt350 Don't worry, the mps is all self contained. T... Apr 30 2025, 06:49 PM
Ron914
Don't worry, the mps is all self contained. ... Apr 30 2025, 07:20 PM
emerygt350 Your favorite FLAPS. Cheap plastic t works fine. ... May 1 2025, 01:46 PM
MDTerp Agree, I use a cheap plastic T connection. Here... May 1 2025, 07:47 PM
ChrisFoley Its a good idea to test the mityvac on a dead ende... May 2 2025, 05:57 AM
Ron914
Its a good idea to test the mityvac on a dead end... May 2 2025, 07:46 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th December 2025 - 12:39 AM |
