Rear shocks & springs |
EJP914 |
Feb 3 2005, 06:59 PM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Need some advice. I have installed KYB rear shocks & "stock"100LB springs on rear of car. Back of the car is jacked up way too high! There is 5 - 5 1/2" from top of wheel to wheel well opening. I want to get to stock ride height at the rear of the car. Is the problem the shocks OR the springs? Do I keep the springs and go with Boge shocks (Bilstein or Koni too rich for me!) OR keep the KYB's and try smaller springs, say 140lb units, which I assume are lower??? Not sure which combination will be correct. As it is, the car looks like a 72 CHevelle my brother in law used to have with the back end jacked up in the air.
Thanks for all replies! |
xsboost90 |
Feb 4 2005, 04:48 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
adjustable boge's on one of the lower settings and some 944 s2 front springs-same diameter and 160lbs. Still have to check it out w/ the motor etc on though.
Attached image(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 05:00 AM |
